Another L.E.D. thread - has it been done?
Old Jan 14, 2009 | 12:31 AM
Cobalt2921's Avatar
Hey all. Here's what I'm thinkin' here. I'd like to get some tubed LEDs from Oznium's website and wire em to the floor boards. I know, same ole idea right? I had an additional idea. Do you think I'd be able to wire them up to the dome light so that when I open the doors, the lights come on? If so, would it be possible to fix that problem with the LED dome light where its very dimly on, even if the switch is in the middle (light on with door open). Think this would be a good idea?
One more quick thing.. Was thinking some thin LED's for under the door itself, to shine on the ground when the door is opened. Could it be done as well as the above idea? Thanks!
Old Jan 14, 2009 | 12:43 AM
cobaltss86's Avatar
the leds when the door is open has been done by a member and i'm pretty sure you can wire to your dome light not sure how hard but i would think it would be easy.
Old Jan 14, 2009 | 12:46 AM
Cptn Pants's Avatar
Yep, it sure can be done... i did it over the summer. At least the under the door parts. It's not to hard really, basically you are going to use the door switches (the ones that are pushed when the doors are closed) as a ground, I used the interior lights fuse as the hot wire. When the switches are released then it completes the circuits are closed and the lights shine down. It's a very fancy effect if I do say so myself. Good luck!
Oh, i almost forgot, i used these LED strips, they are thin enough that they can fit on the bottom of the door sill even when the door is closed.
Check out my ride.
Old Jan 14, 2009 | 01:07 AM
Cobalt2921's Avatar
Damn those look good! I'm definately lovin the idea after seeing someone who has done it. Think i could order some up this week thanks for the pics and info!
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Builttss
Oct 4, 2015 10:21 AM
riceburner
Oct 2, 2015 05:47 PM
ThoR294
Sep 28, 2015 05:31 PM
