CCFL Projectors from ebay
so um...how the hell do you aim THESE? as in, which screws do what?
I've turned all 3 several times...so far noticing no real change. also only seeing adjusting screws around the highbeam housing....not around the projector housing.
pics (drawn or photo) would be great. thanks.
those aren't the same headlights as mine.
neither write up is relevant to my application...thanks though.
these are mine:
http://cgi.ebay.com/ebaymotors/05-06...spagenameZWDVW
more or less anyhow...mine are black. if you look closely at that pic, you'll see 3 adjustment screws around the high beam housing, but none around the low...my highs are aimed A-OK, but the lows are basically worthless at this point :-\
these are mine:
there are two dials on the back, one gold one silver. bottom one is left and right top is up and down. park your car 25 feet away from a wall and line up the cut off lines
check what your states law is for the height of the headlight projection from 25 feet away
Last edited by BOOSSTED 06; Mar 27, 2008 at 05:29 AM. Reason: Automerged Doublepost
