CF Trunk Install - Adjusting it to sit flush?
Old Mar 30, 2010 | 05:14 PM
mkulrey13's Avatar
So i just installed my ViS Carbon Fiber Trunk. Wondering how i would go about adjusting it so it sits flush with the car? I turned the knobs on the hinges and it still sits high. Once side is alot worse then the other. Should i remove my struts?
Old Mar 30, 2010 | 05:24 PM
Put name here's Avatar
I had to "massage" the trunk lip a little and move my trunk latch mechanism up into the trunk lid a little. I found the bottom lip to be the biggest thing in the way (had to move to back) and the part where the trunk lip turns down. I wonder if the people who make the trunks have actually tried to fit them to a car lol. Had to silicone around the rear lights after finding a good amount of water made it past them in the car wash.
Old Mar 30, 2010 | 06:00 PM
mkulrey13's Avatar
Lip fits fine, its near the back and top of trunk.
Old Mar 30, 2010 | 07:36 PM
Mine fit ok at the top however it didnt fit fine until i got the bottom to sit properly. I dont have a vis trunk so probably different. I used a piece of paper to determine where it was tight. Took latch off and leaned on it and where paper was tight while trying to remove it is where i 'adjusted' it. The top by the backglass had tons of room but the back botton screwed up all adjustments. Nothing worked until i fixed that.
gl
edit: i also noticed when i pushed the trunk down that the bottom was pushing 'out'. check that. If its doing it that trunk lip is in the way.
Old Mar 30, 2010 | 07:38 PM
ls1fbody's Avatar
Haz l33t wheelz.
the brackets on the side have two bolts each, loosen them and you can settle the trunk a little. Let me see if i have a picture...
I don't have a picture, but the two bolts i'm talking about attack the hinge to the body of the car.
Old Mar 30, 2010 | 07:47 PM
mkulrey13's Avatar
Yes those bolts i adjusted and they didnt do anything lol
Old Mar 30, 2010 | 07:50 PM
ls1fbody's Avatar
Haz l33t wheelz.
ok, well there's a bump stop on each side, then there are the actual brackets, It helped mine, but not 100%
There may be no way to lower it any more without cutting.
Old Mar 30, 2010 | 07:53 PM
didnt cut mine...fits ok now. Used hammer and block of wood with a little effort. First got to figure out where its hitting or deal with a trunk that sits up a qtr inch at the back lol.
ernnyyes
Oct 2, 2015 05:16 PM
justinchinn
Oct 2, 2015 12:18 PM
Tupp
Sep 30, 2015 08:18 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
