Cobalt Rollcage
Old Oct 24, 2007 | 04:33 AM
CobaltDemon's Avatar
Cobalt Rollcage
Ok I was just curious as to how many of you guys have the Gravana Rollcage installed or have any kind of rollcage installed?Im just curious
Old Oct 24, 2007 | 08:21 AM
alleycat58's Avatar
I will have one eventually, just no money now or in the forseeable future. If you have a shop that can fab one, if you search around GM put out a build book on how to build a Cobalt rollcage.
Old Oct 24, 2007 | 10:19 AM
im thinking of having my bro fabricate that rollcage tehy did or installing the gravana one. y bro is able to weld stuff up
Old Oct 24, 2007 | 10:31 AM
alleycat58's Avatar
You can do quite a bit of research on it, I'd fab it if at all possible, then you can have a lot more say into how it's positioned. Some cars end up having a cage that's barely visible from outside the car.
Old Oct 24, 2007 | 11:44 AM
PlaysWitCars's Avatar
Former Cobalt Owner
I am also curious about the gravana roll cages.....
Old Oct 24, 2007 | 11:49 AM
Scythe_Snake's Avatar
They look all out race suited. If it was just a half I'd be interested. And on the street rollcages are dangerous. You get into an accident with one of those without a helmet it can be like a baseball bat to the head.
But it looks interesting none the less.
Old Oct 24, 2007 | 11:54 AM
SKCobalt's Avatar
I think alleycat has a good point. Custom fabricating a cage can allow you to position the bars where they are best for your situation, which can reduce the safety concerns on the street. Like Snake pointed out, they can be dangerous on the street if you do not install them properly. You should have the tubes wrapped where any part of your body could touch it. There is stuff out there that is made for wrapping roll cages for padding.
Old Oct 24, 2007 | 12:48 PM
yea its a high density foam padding.thats whats used to wrap the rollcage bar where any part of your body might come in contact with the rollcage. most likely ill do some research and my bro can weld it up for me.
Old Oct 24, 2007 | 01:50 PM
alleycat58's Avatar
That's why you fab for a street car.
^^^Exactly. You can even have partially removable roll cages. I've seen it done personally. You also have the fabber design the entire cage AROUND you, which is the whole point of having one. I've talked to several fab places around here. One preference for street cars is to put the behind-the-front-seats bars low, so they hit across the upper middle of the seats. That way a) your head isn't going to hit it and b) it's at a prime location to siffen up the car in the event you get t-boned.
You get the right fab guy and you'll get exactly what you need. Usually they have design differences between drag cars and track cars, because the rigidity needed is different. A drag car isn't extremely likely to roll (though they sometimes do), whereas a track car is VERY likely to roll, be t-boned, hit walls and cars at odd angles, etc.
Some peopel once they get a cage get paranoid about an accident and hitting the bars so they opt to wear DOT harnesses even when street driving because they keep you more stationary.
You can also add extra padding if need be. There's race padding and then if you want a little extra impact protection you can add some more for a daily driver.
Old Oct 24, 2007 | 04:27 PM
Fabbing for the win! I'd look into fabbing one up as well. That would be nice!
Old Oct 25, 2007 | 02:58 PM
yea thats my plan. Im going to get it fabricated
Old Oct 25, 2007 | 03:13 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
Remember, with a cage your seats won't recline and the back seat will be a PITA to get into, not that the driver cares
Superslowbaltt
Sep 22, 2015 10:24 AM
Rayray2781@gmail.com
Sep 20, 2015 01:52 PM
Bluelightning
Sep 8, 2015 05:18 PM
jthwjde
Sep 7, 2015 09:24 AM
