Dead Battery after IPCW Tail lights
Just installed the IPCW LED tail lights yesterday. Tested the brake, turn signal and everything else. Worked perfect
Today I go to start the engine and the battery is completely dead. Not even enough power to run the radio.
Also the CEL and GM Security Light both go on
There is a steady clicking sound from the center console that only goes away after I take the key out.
I had to put the stock ones back in and now my batt. is dead. Gotta get jump started and see if I dindn't set off a GM security light.
Then I have a whole new set of problems
What a hassle
What a hassle
I did but all the wiring is fine.
Now the engine does not start. Instead I head a clicking in the center console that goes off like crazy. Then the CEL and Security Light will appear on the dashboard.
The clicking doesnt stop until I take the key out.
Since I have a battery charger I took out the batt and charge it overnight.
Jumping it from my buddy's car did not help.
Turbo timer shows 6v. but only for a sec. before it shuts off.
See what happens tomorrow.
guess your car is messed up because i installed my ipcw lights and had no problem. i even took them completely out and put them back in and still no problem
check your car over and make sure its not messed up.
I'm hoping that my battery is dead from the -7 Celcius cold nights and it has nothing to do with tail lights. Then I'm only out the $150 for a new Battery and I can put the lights back in.
I think the both of you are right
Just a big coincidence that my battery died the day following my tail lights install. That made me pin the blame on the tail lights when infact I might just need a new battery
Damn I hate it when that happens
Thanks for all the replys
I'm pretty sure it's not the tails. I had the IPCW tails for almost 3 years with no problems. The coldest i ever started my car (without being plugged in) was in - 25C. It was a little rough but started ok.
LOL X3
Alot of people told me they don't like these tail lights. It angers alot of people just the sight of them
So I should I post pics or not?
Let's vote
That's what it was. It took 10 hours to charge my old battery at low 2 amps setting but I managed to get the cobalt started and drive over to the auto parts store.
AC Delco OEM Battery was only $109
Problem gone, I'm glad
Nothing wrong with the IPCW's but I won't delete this thread since it might someday help someone who has a similar engine won't start/clicking sound/CEL/GM Security light problem
Let's vote
Sl0wbaltSS
Nov 21, 2018 11:11 PM
