Do I Cut These Off????
Old Apr 10, 2011 | 03:16 PM
DiabeticKripple's Avatar
was shaving down where the cross member was cut off yesterday, as it was out like an inch and i noticed these tabs in my lower grille hole and i have not seen them on another car, so im wondering if i should cut them off?
Old Apr 10, 2011 | 03:23 PM
overboostedss's Avatar
Noooooooooooooooooo just got my new one on. Don't do it!!!!!!
Old Apr 10, 2011 | 04:33 PM
Old Apr 10, 2011 | 04:38 PM
Perfect.disguise's Avatar
They mount to the bumper beam. Unless you have an IC or HE keep them.
Old Apr 10, 2011 | 04:41 PM
ok thank you
Old Apr 10, 2011 | 04:45 PM
CobaltSS89's Avatar
mine are cut off, just cause the H/E though
Old Apr 10, 2011 | 05:11 PM
ill leave them, and tell my painter not to paint them so you cant see them. but if they get in the way for any reason, ill cut them
Old Apr 10, 2011 | 07:58 PM
reefone's Avatar
no. those tabs bend backwards into the bumper and conect to the rebar behind the bumper.
Old Apr 10, 2011 | 10:14 PM
1LSJ2NV's Avatar
Cobalt Nation
Keep them unless you get a IC or H/E where there too big and the tabs wont fit
Old Apr 10, 2011 | 10:31 PM
Rebar?
Old Apr 10, 2011 | 10:46 PM
bogalusahondakiller's Avatar
As said above that holds the center of the bumper to the crash bar
Old Apr 10, 2011 | 10:48 PM
EXsoccer1921's Avatar
Originally Posted by Perfect.disguise
Rebar?
constructionbalt
Old Apr 11, 2011 | 10:17 AM
reefone's Avatar
Rebar?
thats what they call the metal bumper behind the plastic bumper cover.
Old Apr 11, 2011 | 10:28 AM
It's the bumper/bumper beam/ crash bar.
This is rebar.
Old Apr 11, 2011 | 10:32 AM
Staged07SS's Avatar
Administrator
Administrator
Old Apr 11, 2011 | 10:46 AM
reefone's Avatar
This is rebar.
it can also be called a rebar.
bumper rebar - Google Search
at the body shop i go to thats what they call it.
Old Apr 11, 2011 | 11:05 AM
smitzk01's Avatar
I will be cutting mine. I could unbolt the bumper bar bolts that hold the heat exchanger and put them back in but I can't find a real reason to save them. they don't seem to make the bumper any more sturdy (it doesn't wobble or sag with them not bolted up).
hacadacalopolis
Oct 28, 2015 06:09 PM
How to Guide
57
Oct 15, 2015 11:56 AM
Tupp
Sep 30, 2015 08:18 PM
Extreme Dimensions
Sep 24, 2015 05:24 PM
budah93
Sep 23, 2015 02:26 PM
