Does Anybody Have MP Housings?
Old Jan 20, 2009 | 07:59 PM
wardzach2007's Avatar
If you do, do you have a HID bulbs in them? If so, did they originally fit or no?
Old Jan 20, 2009 | 08:02 PM
yellowltcoupe22's Avatar
clarify your question
Old Jan 20, 2009 | 08:05 PM
What do you mean?
MP only sells 1st Gen. But they come with Halogen bulbs in them. But when I bought HID's for it, they didn't fit so I had to drill a hole. I was wondering if I bought a new set, is there anyone out there that bought an HID kit that actually fit their housings.
Old Jan 20, 2009 | 08:07 PM
mkulrey13's Avatar
no. you need to drill a hole. there not deisgned for hids...
Old Jan 20, 2009 | 08:08 PM
ok thats what i was thinkin you meant but wasnt sure.
all the first gen lights has to have a hole drilled to make the hid bulbs fit. all the after market projectors say not to put hids in them so thats why it the spot you had to drill the hole isnt there on the first gens. im not sure of the reason they say not to use hids in them but they do.
mike beat me to it but he's right
Last edited by yellowltcoupe22; Jan 20, 2009 at 08:08 PM. Reason: Automerged Doublepost
Old Jan 20, 2009 | 08:10 PM
Well that just sucks! 1st Gen is the only gen I like. Oh well, ill buy a new set and drill a hole and make sure I wont get any shavings in there. Thanks guys!
Old Jan 21, 2009 | 02:57 AM
liljone's Avatar
I had to drill a hole too gl with the shavings..I got shavings in my housing but you cant tell unless you look real real close.
Old Jan 22, 2009 | 02:38 PM
Cobalt08LS's Avatar
not true.
i have hids in my 1st generations,and no drilling was needed.
Old Jan 26, 2009 | 09:47 PM
SC07's Avatar
does the hole for the return lead need to be on the top or bottom of the bulb housing?
what works best because im not sure this has ever been clarified.
how does the output and cutoff look?
Old Jan 26, 2009 | 09:48 PM
the cutoff of my housings are perfect.
Originally Posted by Cobalt08LS
not true.
Where did you buy your housings?
Last edited by wardzach2007; Jan 26, 2009 at 09:48 PM. Reason: Automerged Doublepost
Old Jan 26, 2009 | 09:57 PM
SC07's Avatar
so where did you drill the hole?
top or bottom.
ALL of the gen 1's need drilling you might just not have the bulb in there right.
there should be a slot ALL the way through the bulb seat for the return lead(small blue wire on outside of bulb)
if you do not drill the slot the bulbs are in cockeyed.
my question is, what produces the best light output, top or bottom drilling?
Old Jan 26, 2009 | 10:01 PM
top or bottom.
Don't know about that bro, I had a performance shop drill mine. Sorry man.
Old Jan 27, 2009 | 06:13 PM
Cobalt08LS's Avatar
i didnt drill mine and there in there fine
Old Jan 28, 2009 | 12:01 AM
Do you have pics of the housings and the cut off?
Old Jan 28, 2009 | 12:12 AM
codytheoutlaw's Avatar
a trick for not getting shavings in the housing is put vasaline on the drill bit. the shavings will stick to the bit instead of falling in. just dont put to much on or drill to fast because it can sling off inside and then you would have a mess lol
Old Jan 28, 2009 | 12:13 AM
How did you come up with that?
Old Jan 28, 2009 | 12:15 AM
its the same way you tap an oil pan for a turbo/supercharger return line without removing it.
Old Jan 28, 2009 | 12:18 AM
ecotecon18s's Avatar
some straight shade tree mechanic **** right there...that works!!!
Old Jan 28, 2009 | 01:13 PM
Cobalt08LS's Avatar
i got mine off ebay. for around 160
http://cgi.ebay.com/ebaymotors/2005-...Q5fAccessories
thats what i got
and i just noticed the cut off was a little off but i think pepboys messed it up the few weeks ago
but its not bad for most part its perfect aimed
and i dont have any pics ill have to take some
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
Slick_Nick
Sep 28, 2015 09:15 PM
