ebay projectors and HIDs ?
Old Aug 17, 2007 | 02:07 PM
JeremyB's Avatar
i was gonna order a set of the helo projectors off ebay and a set of HID lights from xtralights.com but several people told me that the hid's will melt or burn the projectors i doubt that will happen but i figured it wouldnt hurt to ask before i ordered them !!!!
J
the reason they said it would damage the projectors was because the sets sold on ebay are cheap
Old Aug 17, 2007 | 02:14 PM
Jesse_Chouinard's Avatar
I couldn't confirm, but i heard that hids do burn as hot as halogen light!
and by the way i just bought hids off ebay and they work great!! 91 $us
Old Aug 17, 2007 | 02:20 PM
CinciSS07's Avatar
they will be fine. hid's run the same heat as halogens if not cooler. order them. you will be fine. the only thing you have to do is cut a small bit on the inside of the projector so the hids fit, but you can check the how to section for that, very easy mod.
Old Aug 17, 2007 | 02:25 PM
Rangerondubz's Avatar
J
The HID's(35W) in fact run at a cooler temperature then the stock halogen bulbs(55W), they will not melt/burn anything w/ a housing made to withstand the temperature of a halogen bulb. The only thing you willl have to do is make small tab so the HID bulbs return lead can fit through the hole.
Old Aug 17, 2007 | 02:27 PM
CCBalla10's Avatar
hes right....hid is a lot cooler than halogen
Old Aug 17, 2007 | 02:46 PM
thedub784's Avatar
thats tight i didn't know that, i'm buying some!!
Old Aug 17, 2007 | 03:42 PM
JeremyB's Avatar
thanks guys just wanted to make shure im
hacadacalopolis
Oct 28, 2015 06:09 PM
chefhhr
Oct 26, 2015 10:36 PM
Oct 21, 2015 11:57 PM
footballplaya3k
Wheels and Tires
Oct 8, 2015 05:24 PM
Tupp
Sep 30, 2015 08:18 PM
