Front And Rear Lip Question
Bump.
Bump.
I think it's 12 for the front and 14 clips for the back. Yeah and don't use double sided tape
or just go to GM parts direct and it'll tell ya how many clips
Last edited by hailcesar75; Dec 12, 2008 at 06:49 AM. Reason: Automerged Doublepost
because its not gonna work. you need the ls/lt bumper. the 2.4 ss has the weird black half lip or whateve ryou want to call it. thats gonna get in the way if i'm not mistake...
in your diagram there, the ls bumpers will use steps 1-13, the ss/sc will use 1-17. the 2.4 is a whole different bumper
Even if that was the case, it wouldn't matter because I have a brand new 2.2L bumper sitting in my garage that someone local gave to me for free.
then why doesn't the 2.4 bumper have slits in them for a lip?? they aren't gonna fill those for every bumper that goes on a 2.4 and not a 2.0. the 2.4 is a seperate bumper for the rear. the ls and ss/sc are the same, the only difference is slits will be cut in for the ones going on a 2.0 and then the lip will be installed.
Are the clips for the front lip universal for the rear as well? If not, then can someone point out which number is the clip for the rear lip?
Bump.
Bump.
Its not doing it cheap.... thats what body shop 2 sided tape is for. You don't think the big three never use two sided tape to hold on body trim amd small body panels, hahahhahahha your sadly mistaken. If your having it professionally done then I mis understood. I ASSUMEd you where thinking of doing it yourself. My bad. I was trying to save ya the hassle of trying to cut the sloys yourself and ruining your car and or paint job.
OBTW... it WOULD hold it no problem and would pull your paint off before falling off. Those two pieces weight nothing.
