Front And Rear Lip Question
Old Dec 10, 2008 | 08:35 PM
ssweeet's Avatar
How many retainers would I need for the front and rear lip pieces.
Old Dec 10, 2008 | 08:40 PM
BlueByYou's Avatar
the stock GM lips .... there already attached and fit into slots cut in the bumber cover. So if your not already a SC or TC then cut of tabs and use two sided tape.
Old Dec 10, 2008 | 11:50 PM
ssweeet's Avatar
I'm not doing it cheap. I'm doing it the right way and having it professionally installed.
Bump.
Bump.
Old Dec 11, 2008 | 09:11 AM
NCC-2000's Avatar
Double sided tape won't hold up the way the factory clips do. There's a how to on here for installing the lips, it tells you how many clips you need for the front and rear lips.
Old Dec 12, 2008 | 06:49 AM
hailcesar75's Avatar
I think it's 12 for the front and 14 clips for the back. Yeah and don't use double sided tape
or just go to GM parts direct and it'll tell ya how many clips
Last edited by hailcesar75; Dec 12, 2008 at 06:49 AM. Reason: Automerged Doublepost
Old Dec 12, 2008 | 08:20 PM
ssweeet's Avatar
Thanks.
Old Dec 12, 2008 | 08:23 PM
EXsoccer1921's Avatar
then let them worry about it. and don't plan on putting the ss/sc rear lip on the 2.4 ss rear bumper
Old Dec 12, 2008 | 08:24 PM
ssweeet's Avatar
Why is that?
Old Dec 12, 2008 | 08:27 PM
Acey's Avatar
Why not? Bumpers are exactly the same. SS/SC bumper is 2.4 bumper + lip. Or rather, since the SC was out first, the 2.4 bumper is the SS/SC bumper sans the lip.
Why is that?
because its not gonna work. you need the ls/lt bumper. the 2.4 ss has the weird black half lip or whateve ryou want to call it. thats gonna get in the way if i'm not mistake...
in your diagram there, the ls bumpers will use steps 1-13, the ss/sc will use 1-17. the 2.4 is a whole different bumper
Old Dec 12, 2008 | 08:37 PM
ssweeet's Avatar
No you're mistaken. The 2.2L bumper is the one that doesn't fit the SS/SC rear lip. The 2.4L and 2.0L bumpers are the same.
Even if that was the case, it wouldn't matter because I have a brand new 2.2L bumper sitting in my garage that someone local gave to me for free.
Old Dec 12, 2008 | 08:41 PM
then why doesn't the 2.4 bumper have slits in them for a lip?? they aren't gonna fill those for every bumper that goes on a 2.4 and not a 2.0. the 2.4 is a seperate bumper for the rear. the ls and ss/sc are the same, the only difference is slits will be cut in for the ones going on a 2.0 and then the lip will be installed.
Old Dec 12, 2008 | 08:43 PM
ssweeet's Avatar
The have slits. They just need to be cut. If you've ever seen the inside of a 2.4L bumper you'll see the little boxes for the slits to be cut out. LS and SS/SC are not the same. One is elongated.
Old Dec 12, 2008 | 08:45 PM
MufcDroog's Avatar
correct
oh well. you have both bumpers. they'll know what to do
Old Dec 12, 2008 | 08:54 PM
ssweeet's Avatar
Thanks for your input though.
Old Dec 13, 2008 | 12:02 AM
jschatte's Avatar
actually you can put the lip on both the 2.4 and 2.2 bumpers... there is how tos for both
Old Dec 13, 2008 | 08:56 AM
^^^x2 and on sedan too
Old Dec 13, 2008 | 09:47 AM
chevy cobalt 08's Avatar
You said you need to cut the stock bumper for a sedan. Please make a how-to on fitting a rear lip on a sedan!
Old Dec 13, 2008 | 05:29 PM
ssweeet's Avatar
Are the clips for the front lip universal for the rear as well? If not, then can someone point out which number is the clip for the rear lip?
Bump.
Old Dec 14, 2008 | 07:59 AM
NCC-2000's Avatar
The clips are the same for front and rear, you just need a lot of them.
Old Dec 14, 2008 | 10:28 AM
Doood! It's the same as the how to
Old Dec 14, 2008 | 01:55 PM
ssweeet's Avatar
Thanks. I ordered the rear first.
Old Dec 15, 2008 | 06:04 PM
BlueByYou's Avatar
Its not doing it cheap.... thats what body shop 2 sided tape is for. You don't think the big three never use two sided tape to hold on body trim amd small body panels, hahahhahahha your sadly mistaken. If your having it professionally done then I mis understood. I ASSUMEd you where thinking of doing it yourself. My bad. I was trying to save ya the hassle of trying to cut the sloys yourself and ruining your car and or paint job.
OBTW... it WOULD hold it no problem and would pull your paint off before falling off. Those two pieces weight nothing.
Old Dec 15, 2008 | 06:08 PM
slowswap's Avatar
Rear lip going on the 2.4 bumper. Look at any 2.0 and you'll see its the 2.4 bumper with the lip attached.
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
