Full LED conversion?
wtf happened to ur whip
Last edited by gotboost?17; Mar 6, 2011 at 07:50 PM. Reason: Automerged Doublepost
Not all led fit the specific size of the light in the cobalt like the one for rear side marker
Alright here's a list of the bulbs Cobalts use and the LED bulbs I'm using to replace the stock ones.
Front Turn Signal - 3157
Amber LED - V-LEDS AMBER 7W HIGH POWER 20 LED TURN SIGNAL BULBS 3157 3156 4057
Switchback Type 1 - V-LEDS TYPE 1 DUAL COLOR CHANGING HID WHITE AMBER SWITCHBACK 60 M-SMT TURN SIGNAL BULBS 3157 3157NA 3357 3457 4157 4057
Switchback Type 2 - TYPE 2 DUAL COLOR CHANGING HID 6K WHITE AMBER SWITCHBACK 60 M-SMT TURN SIGNAL BULBS 3157 3157NA 3357 3457 4157 4057
Resistors - 6 OHM 50W 2 BULB LED LOAD EQUALIZER RESISTORS TURN SIGNAL BLINKER FIX
Front Side Marker - 194
White LED - 2 V-LEDS 5K WHITE 194 13 LED LIGHT BULBS 158 168 2825 B/O
Rear Side Marker - 194
Red LED - 2 V-LEDS RED 194 13 LED LIGHT BULBS 158 168 2825
License Plate - 194
White LED Flank Bulb - V-LEDS HID WHITE 6 LED M-SMT FLANK BULBS 194 168 158 2825
High Power White LED Flank Bulb - V-LEDS HID 6K WHITE 4 LED 2 WATT HP M-SMT FLANK BULBS 194 168 158
Brake Lights - 3157
Red High Power LED - 2 RED 3157 V-LEDS 7W HIGH POWER 20 LED BRAKE LIGHT BULBS 3156 4057
Reverse Lights - 921
White LED - V-LEDS HID WHITE 19 M-SMT 8W HIGH POWER BULBS 917 918 920 921 922 923
Map Lights in Rear View Mirror - 194 (Technically, it's 2825, but 194s fit)
White LED - 2 HID 6K WHITE SMT X5 HIGH POWER LED LIGHT BULBS 194 168 158 2821
Dome Light - 562
White LED - HI POWER 3 LED 5K WHITE DOME LIGHT BULB 561 562 564 212-2
Dome Light Map Lights (For those that have them) - 194
White LED - V-LEDS HID 6K WHITE 4 LED 2 WATT HP M-SMT FLANK BULBS 194 168 158
Trunk Light - 194
If the map lights in the rear view mirror don't give you enough light, I created a how-to for installing a dome light in a sunroof car, makes a hell of a difference in lighting. As far as the brake lights go, I have a set of LED tails, so I don't actually use LED bulbs in mine, but the ones linked will do the job just fine.
For the license plate and dome map lights, I suggest using the flank bulbs since they will only light up in one direction rather than all around. This is useful because of the way the bulb is positioned over the plate and in the dome light, that way all the light the bulb produces will be going to what you want lit up.
Any other questions, I'll be glad to try to help.
License Plate - 194
Brake Lights - 3157
Dome Light - 562
Trunk Light - 194
Sl0wbaltSS
Nov 21, 2018 11:11 PM
