Full LED conversion?
Old Mar 6, 2011 | 04:55 PM
  #51
09xfebalt's Avatar
This looks awesome :
thanks i wanted a trunk light that actually did something so i made this
Old Mar 6, 2011 | 04:58 PM
  #52
Subd
Old Mar 6, 2011 | 05:00 PM
  #53
keiserX13's Avatar
what did you use? looks like there's 4 light sources
Old Mar 6, 2011 | 05:18 PM
  #54
09xfebalt's Avatar
your close theres 5 3 down middle and two pointing towards seats. I made my own PCB boards and solder super bright leds to them and tied into trunk light wiring.
Old Mar 6, 2011 | 05:53 PM
  #55
Ph3lix_004's Avatar
heres some pics of mine
how hard was it to do this and do you have a list of the bulbs?
Old Mar 6, 2011 | 05:55 PM
  #56
09xfebalt's Avatar
I have a how to thread in the how to secton that includes a list
Old Mar 6, 2011 | 05:57 PM
  #57
gotboost?17's Avatar
Nothin Stock
how r u guys pullin the map lights out i cant get a good grip on it wit my fingures?
Old Mar 6, 2011 | 06:12 PM
  #58
keiserX13's Avatar
i used a dental hook LOL got right under it then i could pull
ive also used a small screwdriver and pried it out
Old Mar 6, 2011 | 07:26 PM
  #59
Ph3lix_004's Avatar
thank you sir will be doing this! very clean lookin interior
Old Mar 6, 2011 | 07:50 PM
  #60
Nothin Stock
ohh okay if got hook pliers
wtf happened to ur whip
Last edited by gotboost?17; Mar 6, 2011 at 07:50 PM. Reason: Automerged Doublepost
Old Mar 6, 2011 | 08:11 PM
  #61
Ph3lix_004's Avatar
Lol lugs snapped off
https://www.cobaltss.net/forums/prob...inside-243458/
Old Mar 6, 2011 | 08:13 PM
  #62
Nothin Stock
damn thats shyt!!!
Old Mar 6, 2011 | 08:31 PM
  #63
Ph3lix_004's Avatar
damn thats shyt!!!
haha ya......
Old Mar 7, 2011 | 08:00 PM
  #64
C_A_D88's Avatar
any one know where i can get a bright led rigid loop festoon bulb?
Old Mar 7, 2011 | 10:24 PM
  #65
keiserX13's Avatar
have you checked superbrightleds.com?
Old May 25, 2011 | 07:24 PM
  #66
el_angelito's Avatar
Not all led fit the specific size of the light in the cobalt like the one for rear side marker
Originally Posted by NCC-2000
Alright here's a list of the bulbs Cobalts use and the LED bulbs I'm using to replace the stock ones.
Front Turn Signal - 3157
Amber LED - V-LEDS AMBER 7W HIGH POWER 20 LED TURN SIGNAL BULBS 3157 3156 4057
Switchback Type 1 - V-LEDS TYPE 1 DUAL COLOR CHANGING HID WHITE AMBER SWITCHBACK 60 M-SMT TURN SIGNAL BULBS 3157 3157NA 3357 3457 4157 4057
Switchback Type 2 - TYPE 2 DUAL COLOR CHANGING HID 6K WHITE AMBER SWITCHBACK 60 M-SMT TURN SIGNAL BULBS 3157 3157NA 3357 3457 4157 4057
Resistors - 6 OHM 50W 2 BULB LED LOAD EQUALIZER RESISTORS TURN SIGNAL BLINKER FIX
Front Side Marker - 194
White LED - 2 V-LEDS 5K WHITE 194 13 LED LIGHT BULBS 158 168 2825 B/O
Rear Side Marker - 194
Red LED - 2 V-LEDS RED 194 13 LED LIGHT BULBS 158 168 2825
License Plate - 194
White LED Flank Bulb - V-LEDS HID WHITE 6 LED M-SMT FLANK BULBS 194 168 158 2825
High Power White LED Flank Bulb - V-LEDS HID 6K WHITE 4 LED 2 WATT HP M-SMT FLANK BULBS 194 168 158
Brake Lights - 3157
Red High Power LED - 2 RED 3157 V-LEDS 7W HIGH POWER 20 LED BRAKE LIGHT BULBS 3156 4057
Reverse Lights - 921
White LED - V-LEDS HID WHITE 19 M-SMT 8W HIGH POWER BULBS 917 918 920 921 922 923
Map Lights in Rear View Mirror - 194
(Technically, it's 2825, but 194s fit)
White LED - 2 HID 6K WHITE SMT X5 HIGH POWER LED LIGHT BULBS 194 168 158 2821
Dome Light - 562
White LED - HI POWER 3 LED 5K WHITE DOME LIGHT BULB 561 562 564 212-2
Dome Light Map Lights (For those that have them) - 194
White LED - V-LEDS HID 6K WHITE 4 LED 2 WATT HP M-SMT FLANK BULBS 194 168 158
Trunk Light - 194
If the map lights in the rear view mirror don't give you enough light, I created a how-to for installing a dome light in a sunroof car, makes a hell of a difference in lighting. As far as the brake lights go, I have a set of LED tails, so I don't actually use LED bulbs in mine, but the ones linked will do the job just fine.
For the license plate and dome map lights, I suggest using the flank bulbs since they will only light up in one direction rather than all around. This is useful because of the way the bulb is positioned over the plate and in the dome light, that way all the light the bulb produces will be going to what you want lit up.
Any other questions, I'll be glad to try to help.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
brandon04
Oct 21, 2015 07:04 AM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
