gen 1 leds problem, please help
Old Feb 5, 2009 | 08:52 AM
minag3's Avatar
So... here's my story (which i think many people here have experienced)
I bought the gen 1 projectors from a previous coblat owner and i put them on...no issues, everything works fine, low beam, high beam, 3 leds and the signals, so i'm
2 weeks later (yesterday), I installed my HID hit (H1 bulb) ...fits fine... turn on the car, and ... some of my leds are not working (i have only 1 lite on each side).
Now i read something about the resistors and how it should be 680 ohms or something, but before i go an fidle around with that, i want to make sure i'm doing the right thing to fix'em.
ideas? thoughts? and help?
Thanks in advance
Old Feb 5, 2009 | 08:59 AM
JPizzle's Avatar
The HID's should have NO effect on your LED's......
Old Feb 5, 2009 | 09:16 AM
RedEcotecSS's Avatar
check your wiring... maybe try changing around your LED's... and yes, its a 680ohm resistor for the LEDs.. none of mine were working on one side so I swapped out resistors and it worked again.
Old Feb 5, 2009 | 04:15 PM
minag3's Avatar
so do i need 1 resitor for each led or just one resistor for all 3 (per side)?
sorry if this is a stupid question... but i noticed that the 3 leds are wired in sequence so i'm guessing one resitor for all 3 is enough! is that right?
the HIDs are working and they look SWEEEEEEEEEET
BTW, I still need to aim the projectors, can that be done while the projectors are ON the car? if so, how can i reach the screws?
Old Feb 5, 2009 | 05:58 PM
TheCaptain's Avatar
You definately can't aim the projectors on the car. They have to be taken off, adjusted, put on, taken off, adjusted... etc. Until you get it right. They are the best projectors for cutoff and light output though! I'm in the middle of modifying mine with CCFL halos!
Old Feb 5, 2009 | 05:59 PM
2.2blckbalt's Avatar
Shortly after I got my gen one projectors a couple of the halo's went out and the right side led's started flickering. I replaced all the leds and havent had a problem since.
Old Feb 6, 2009 | 07:49 AM
minag3's Avatar
Thanks guys, i bought new super white leds yesterday to replace the ones that came with the projector. I also bought some 680 ohm resistors to connect them to.
As for the aiming... that going to be a hassle, i'm not sure if you guys experice the same thing i am, but taking the headlights out and back in is a HUGE HASSEL, doable but annoying. Anyways, i guess i gotta do what i gotta do.
Old Feb 6, 2009 | 07:53 AM
ilovecars's Avatar
lol? i though you always had to aim em on the car.
Old Feb 6, 2009 | 02:45 PM
minag3's Avatar
I thoguth the same thing, there must be an easier way, maybe put them on a table and light the bulbs from a external car battery or something...
Old Feb 6, 2009 | 06:46 PM
liljone's Avatar
leds can short out easy on gen1, if the wire from one of the leds touch the frame of the car... bam shorted LEDs..happened to me!
no LEDs
Old Feb 9, 2009 | 10:56 AM
minag3's Avatar
So i bought new leds and the resistors, but i have no idea where to put the resistor, i hope i don't have to crack the projector open for this!
Old Feb 9, 2009 | 11:08 AM
PM'd you.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
