Gen 1 little black box
I have a set of Gen 1's and the LEDs don't have any voltage going to them, even when I wire it straight to the battery. I'm thinking that there's something wrong with the little black box attached to the wiring. Does anyone know if I can either replace, fix, or bypass it?
so right now all white wires from each LED are spliced into one wire going into the black box. Should I just take the one wire and attach it to a 12V source or take each individually and put them to a 12V source? I'm assuming the one wire, but i just wanna make sure.
The Halo's in the Gen 1 are just LED's. That black Box has a resistor in it, the lights will work fine without it, but the Halo's wont.
I cut that black box out, wired in a 12V resistor in its place, replaced the LEDS in the halo's with larger blue ones and it looked fantastic
