Gen 1 little black box
Old May 15, 2013 | 08:47 PM
cobythecobalt's Avatar
I have a set of Gen 1's and the LEDs don't have any voltage going to them, even when I wire it straight to the battery. I'm thinking that there's something wrong with the little black box attached to the wiring. Does anyone know if I can either replace, fix, or bypass it?
Old May 15, 2013 | 08:50 PM
YelloEye's Avatar
Sounds a bit odd, perhaps a picture would help. Does the black box have 4 poles on it?
Old May 15, 2013 | 08:59 PM
little box in the middle. it's on both lights and neither of them work.
Old May 15, 2013 | 09:06 PM
Twoozofjuice's Avatar
I wanna say they need to be connected to something and those don't look to be connected.
Old May 15, 2013 | 09:12 PM
lol, i knew someone would say that! i unplugged it to take it out and take the picture!
YelloEye's Avatar
No idea what that is. Mine didn't have that box. Should be able to just hook up the LEDs to 12v power, maybe in series though. Depends on how they did them.
Old May 15, 2013 | 09:21 PM
so right now all white wires from each LED are spliced into one wire going into the black box. Should I just take the one wire and attach it to a 12V source or take each individually and put them to a 12V source? I'm assuming the one wire, but i just wanna make sure.
Old May 16, 2013 | 09:34 PM
Update: I just cut the black box off hoping it would work, and it did!! Thanks to all that put forth some info! Very appreciated!
Old May 16, 2013 | 10:34 PM
YelloEye's Avatar
Winning!
Old May 16, 2013 | 11:50 PM
StevoElSupremo's Avatar
The Halo's in the Gen 1 are just LED's. That black Box has a resistor in it, the lights will work fine without it, but the Halo's wont.
I cut that black box out, wired in a 12V resistor in its place, replaced the LEDS in the halo's with larger blue ones and it looked fantastic
Old May 17, 2013 | 11:01 AM
there's a separate black box for the halos on mine.
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
c_m_shooter
Sep 27, 2015 04:40 PM
