Gen 4 "Performance Lamp" ?
I'm looking to buy a pair of 4 gens with black housing... I'm checking out ebay and I see some for around 160-170~ + shipping. But I also see these others that look the same called "Performance Lamp"
Depo M35-1102P-AS2 Right Side PERFORMANCE LAMP | eBay
What is the the difference between the normal one and the performance lamp?
Also, on a side note if anyone has any pics of a red sport tint SS with the black housing headlights, would they care to share?
And I'm pretty sure that's right side only?
Buy the from Modern Performance at least this way you can have them warrantied if anything goes wrong.
Yeah, that's why I'm so confused. I was hoping to save a few bucks on ebay, but yeah maybe I should just go MPx. Anyone familiar with what HID kit works best with this? I'm probably looking at 6k output.
Awesome! Maybe I should pick a couple kits for my heads and fogs. Problem is I have no idea what I'm doing when buying one haha. What is a slim ballast? And is a relay harness necessary?
Slim ballasts or not in your opinion? Also, wattage? :S
I'm also stuck between 6k and 8k... I kinda want blueish.. but I know that 6k will be better for seeing... Is 6k blue at all?
It all depends on what you want. Are you going to buy High beams and Low beams? Are you also going to get fogs?
I don't think I'll get the high beams. I live in the city and won't use them much.
But I think I'll get the fogs. Wonder if 6k in the headlights and 8k in the fogs would look good.
5,000K 35W (low beams) Slim Ballast, Relay Harness, Lifetime Warranty,
5,000K 55W (high beams) Slim Ballast, Relay Harness, Lifetime Warranty,
5,000K 55W (fogs) Slim Ballast, Relay Harness, Lifetime Warranty,
I wanted maximum light output without going into the yellow.
As far as HIDs, I went 6k heads and fogs from BuyHIDS.com, with one pair of slim ballasts, and one pair of regular ballasts, and relays for both. Left the highs alone.
6k has some blue, and is still plenty bright. Also, stick with 35W; 55W gets you nothing, and can tax your electrical system.
