glue
Old Dec 27, 2006 | 06:00 PM
spaz's Avatar
Canada glue
Hey guys what glues are you using to glue the gutter guard in the bumper and grills.
I tried some jb epoxy and it isn'tworking like I'd hoped. then some polyurethane glue from home depot. taking forever to dry and I don't think it will work. just making a big mess.
https://www.cobaltss.net/gallery/sho...atid=newimages
I have to fix the top part of the grill because of the way it was sitting while it was drying for a day and I am trying to glue something in the lower hole
help me please because I don't want to drill holes and use ties but if I can't get something to work I will have to bause the condensor is getting smashed by rocks and is starting to look crappy
thanks in advance,Chris.
Old Dec 29, 2006 | 04:54 AM
DoubleClutchin_ION2's Avatar
locktite ftw
Old Dec 29, 2006 | 05:26 AM
06' SS2SS's Avatar
I used J B Weld and it worked fine. If you are doing it in a cold garage, that stuff isn't as easy to work with. As far as the top part sagging like it did, it happened to me too. I took it apart and made a template to keep it from sagging. When you do it again use some weight to hold the mesh down, like some large sockets or something like that. I just got my lower grille done and it looks great! The grille is black with big white COBALT letters. I'll post pics when I find my camera.
Old Dec 29, 2006 | 10:07 AM
biohazard's Avatar
Get low
go to home depot.... its called seal all .... its in a red and yellor tube and its gasdoline proof, water proof, and heat proof.... it also dries clear
Old Dec 29, 2006 | 10:16 AM
DTM2188's Avatar
The epoxy worked for me on my mesh grill.
Old Dec 29, 2006 | 11:29 AM
spaz's Avatar
thanks guys I give some of that stuff a try.
Old Dec 29, 2006 | 11:40 AM
Cobalt_SSTuner's Avatar
someone should do a how to on this.
Old Dec 29, 2006 | 12:06 PM
spaz's Avatar
here is where I got the Idea from
https://www.cobaltss.net/forums/show...ighlight=grill
Old Dec 29, 2006 | 12:10 PM
cool, thanks man
Old Dec 29, 2006 | 12:31 PM
an0malous's Avatar
are you talking about the lower opening where your rads are? because if you get under there and have a look there is 6 pushpins, 2 large on top, and 4 small on the bottom.....
that will hold your DIY lower grille perfectly if you design it to have small tabs where the pushpins are.
Im assuming you must be talking about the upper grille though? cuz i cant imagine glueing something permanantly when you can attach it so easily with what is already there for you.
How to Guide
57
Oct 15, 2015 11:56 AM
footballplaya3k
Sep 30, 2015 09:39 PM
NOS2006
How to Guide
Dec 5, 2012 09:00 AM
Ljavy17
How to Guide
18
Dec 18, 2010 02:31 PM
Cobalt30
How to Guide
Mar 4, 2008 12:01 AM
