help with removing shift knob on cobalt SS
I have tried searching high and low, and i have come up with NOTHING.. i have a 2008 SS, and I am wanting to get this god awful shifter knob off, and replaced with one that doesn't suck.. how do i remove the stock one? thanks!
First lower the boot by twisting it and pushing it down. There are some "teeth" that have to line up with some slots before it will slide off.
Next, with boot down, take a small flat headed screw driver and carefully bend back a few of the pins that are holding into a groove in the shifter shaft. (there are four of these pins)
I only had to bend back two and the knob pulled right off.
that doesn't work on the ss/tc. There is a torx screw on the top under the silver and black cap with the shift diagram on it. However, i took the screw out and it was on there pretty solid still. I was afraid i would pull the leather part right off before it came free. Might have to heat it up to get it off. Not sure, i was looking to see if there was a trick to getting it off easily. It's not looking like it...
This is an old thread revived.
Turbo Johnny
Feb 21, 2019 09:41 AM
SS_2009_TC
Sep 11, 2015 05:41 PM
XStylus
Redline Goods
17
Sep 3, 2015 10:30 AM
