help with removing shift knob on cobalt SS
Old Oct 3, 2011 | 12:49 PM
Thanat0s24's Avatar
I have tried searching high and low, and i have come up with NOTHING.. i have a 2008 SS, and I am wanting to get this god awful shifter knob off, and replaced with one that doesn't suck.. how do i remove the stock one? thanks!
Old Oct 3, 2011 | 12:53 PM
SmokinSam06's Avatar
ya dont, its pressed on, only thing you can really do is get a hurst sts and that has a diff knob on it.
welcome to cobalt lol
Old Oct 3, 2011 | 12:55 PM
keiserX13's Avatar
Whats wrong with the stock one?
Old Oct 3, 2011 | 01:02 PM
aLPHaGoD's Avatar
First lower the boot by twisting it and pushing it down. There are some "teeth" that have to line up with some slots before it will slide off.
Next, with boot down, take a small flat headed screw driver and carefully bend back a few of the pins that are holding into a groove in the shifter shaft. (there are four of these pins)
I only had to bend back two and the knob pulled right off.
Old Apr 17, 2013 | 06:22 AM
PyroSiege's Avatar
That doesn't work on the SS/TC. There is a torx screw on the top under the silver and black cap with the shift diagram on it. However, I took the screw out and it was on there pretty solid still. I was afraid I would pull the leather part right off before it came free. Might have to heat it up to get it off. Not sure, I was looking to see if there was a trick to getting it off easily. It's not looking like it...
Old Apr 17, 2013 | 06:51 AM
Powell Race Parts's Avatar
I use a small two jaw puller; the factory says to use a long screw in the center where you removed the locating screw.
Old Apr 17, 2013 | 07:35 AM
CudaJoe's Avatar
follow the TWM directions....
Old Apr 17, 2013 | 07:36 AM
CudaJoe's Avatar
http://www.twmperformance.com/manual...all-manual.pdf
Step 7 refers to the shift knob.
Old Apr 17, 2013 | 07:38 AM
CudaJoe's Avatar
Originally Posted by pyrosiege
that doesn't work on the ss/tc. There is a torx screw on the top under the silver and black cap with the shift diagram on it. However, i took the screw out and it was on there pretty solid still. I was afraid i would pull the leather part right off before it came free. Might have to heat it up to get it off. Not sure, i was looking to see if there was a trick to getting it off easily. It's not looking like it...
Friggen TROLL. YOU got ME
This is an old thread revived.
Old Apr 17, 2013 | 07:41 AM
aweadSS's Avatar
good luck, got so pissed off at mine ended up cutting it off and putting a hurst in.
Turbo Johnny
Feb 21, 2019 09:41 AM
roadrunner132
Sep 19, 2015 04:35 PM
SS_2009_TC
Sep 11, 2015 05:41 PM
SiloGM
Sep 7, 2015 11:04 PM
