HID problem
Old May 23, 2009 | 01:44 AM
BULLETSSMOKE's Avatar
HID problem
I have had my black halo projectors for a while now but I finally installed my HID kit and everything lights up and works fine but when I stuck the bulb in the hole and put everything together it seems there is very very little light coming out and it doesnt light up the road at all. Please help and thanks. I dont want this kit to go to waste.
Old May 23, 2009 | 11:38 AM
wardzach2007's Avatar
Are you sure you have the bulb in there right? And connected right?
Old May 23, 2009 | 11:41 AM
Turbo06Sedan's Avatar
I know when I had my halo's, and put in a HID kit. Same thing, barely saw any light at all.
I ended up taking them out, and putting the halogens back in.
However, my halo's i sold to a friend. and put in a HID kit. worked beautiful.
Could of been a sub par kit.
Old May 23, 2009 | 11:46 AM
wait, which gen do you have?
Gen 1?
Old May 23, 2009 | 01:53 PM
uhhhh i think gen 3 i can find them on ebay hold on
http://cgi.ebay.com/ebaymotors/HID-0...ht_5747wt_1197
its those headlights but i got them off ebay before the HID kit was included in the package. i bought a separate kit. everything sits in there fine and the bulbs light up. it just doesnt light the road up at all. i had to use my fog lights to see last night
Old May 23, 2009 | 04:43 PM
liljone's Avatar
I can see my HID hit the road in the daytime so there defiantly something wrong.
Old May 23, 2009 | 04:48 PM
c0ld29's Avatar
Is the light itself lighting up very bright? (sometimes it can be dim if the bulb is about to go out or is messed up, if you take it out the headlight and turn it on you should just about blind yourself with HIDs lol)
Did you touch the glass part of the bulb at all in installation? (if you did refer to 1)
Did you check to make sure when you put in the new HID bulb that you didnt move the alignment way high or low, left or right?
When you change bulbs especially with HIDs you may need to realign the beams. Pull up next to a wall real close and see if you can see where the cut off is, slowly back up if you see a cut off and if it is misaligned you will see where the patterns go
Old May 23, 2009 | 10:23 PM
well im pretty sure ive touched the bulb before installation a few times and they have been bouncing around in my truck for a while. they are just really really dim
Old May 24, 2009 | 01:32 AM
Spun's Avatar
Plug and Play or Relay Kit?
It sounds like there just pointed at the ground.
My projectors were pointed right down at the ground when I first got them...both sets (2nd and 3rd generation)
Why don't you just post a pic of what it looks like?
Old May 24, 2009 | 12:28 PM
its a plug and play that came with the ballast thing. when i drove last night they seemed to have gotten a LITTLE bit better but i still couldnt see. ill go take a pic
Last edited by BULLETSSMOKE; May 24, 2009 at 12:28 PM. Reason: Automerged Doublepost
Old May 24, 2009 | 12:58 PM
05LSCobalt's Avatar
you might not have the bulb sitting flush witht the base. check that and also the bulb might be a bad one.
Old May 24, 2009 | 01:17 PM
c0ld29's Avatar
I'm not 100% on how HID bulbs work with this although I believe its the same concept in this way to regular halogen bulbs, but if you touch the glass with your fingers the oils get onto it and it ruins the bulb. It will at first be VERY VERY dim, then go out eventually. Could be the culprit.
Old May 24, 2009 | 01:48 PM
ill keep the lights running constantly and see if thats it. because it seems they are very very dim. they are almost aligned properly its just that barely any light comes out of the projector. from both bulbs
Old Jun 2, 2009 | 05:12 PM
CASol's Avatar
if thats what the lights look like on, then its probally the bulbs.
Does the halogens work fine?
Old Jun 3, 2009 | 02:39 PM
halogens work fine. that was in the daylight with the lights off in those pictures, someone said they wanted to see what gen i had
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
