Hid projector help(yeah another one)
Old Apr 5, 2007 | 06:20 PM
grigs's Avatar
Hey guys im having a problem with the hid kit and the projectors... well i have everything set up but i get a lil confused where the two remaining wires that are red and black go... Basically i dont know what wires attach from the hids to the projectors.. sorry if thats a lil confusing im pretty frustrated.. thanks for all the help
Old Apr 5, 2007 | 06:31 PM
Cobalt_SSTuner's Avatar
I dont have projectors, but here's a free bump! Somebody will help ya
Old Apr 5, 2007 | 08:39 PM
grigs's Avatar
sorry to clear things up a little... the hid on the right side where everything is connected will only turn on for a split second... the other one remains on ..could this be because i spliced the wrong wires.. and if so what wires from the hid do i attach to the harness wires... thanks again for any help
i have the vision kit.. i connected the white wire to the orange. and black to the black.. does it matter which black i connect it to... isnt it only a ground?sorry if thats a rook question
hey i fixed it the prong in one of the plugs was bent....
Old Apr 6, 2007 | 02:11 PM
akJBody's Avatar
Is the car running when you fire up the HID? What size Headlamp fuses are you running. Assuming its wired correctly, these are two very common problems. The reason I say this is because you said one lamp turns on for a split second and the other stays on. Cobalts run like a 10 amp fuze for each headlamp. It is recommended your run a 20 amp when powering HID directly through the headlight wiring. The 10 amps will usually work if the car is running, but if it isn't, it's possible to blow a fuse or the ballast won't recieve enough power and the headlight will shut off.
Old Apr 6, 2007 | 03:51 PM
grigs's Avatar
no i fixed it.. the setup is done through a relay .. i jus had a prong broken within one of the plugs
grigs's Avatar
TedSS
101
Apr 25, 2016 10:46 PM
Bluelightning
Nov 11, 2015 02:41 PM
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
dieGone
Sep 23, 2015 10:20 AM
