How many of your painted headlights leak
moisture
i had moisture in one headlight so what i did was remove it bake it in the oven again to get all water to evaporate, then resealed with the permatex ultra black. i laid a big think bead all the way around abd havent looked back.
Originally Posted by HackAbuse
Dude, I love that SS symbol where it is, niiice
i just had that piece from my trunk floating around and what can i say.... these things just come to me.
here is my headlights
the bowtie lights up like so
they still fog up from time to time. which sucks.....so im going to find another pair at a local junkyard and see if i can complete my super secret headlight.
after a about 5 months of having my headlights on.. i noticed today after all the rain we had that my driver headlight is all fogging up. This is making me mad, i think if i reseal it, it will just end up leaking in the future again, so i'm just going to put the regular headlights back in and maybe get headlight covers.
Headlight covers are not very attractive. Fella's...lok at Mercury's how-to on retrofitting. Notice towards the end he inserts some silica gel packages into the headlamp tohelp absorb whatever moisture remains in there after closig them up. Pretty much the only way to ensure no condesnation appears on the headlamps is to seal them when the humidity is extremaly low and air is dry. This means when you plug in the headlight you need those conditions. The silica gel should help with minimal amounts of moisture..just don't eat it :P
the main trick to getting them to seal is how you put them back together. when i did mine, i took a heat gun and ran it around the headlight body for about 5 minutes straight to soften the adhesive that was left in the groove. then i did about 5 laps around the lens to soften that glue while someone else applied silicon to the groove on the headlight body. then i sandwiched them back together and held them shut for about an hour with clamps.
here's a couple pics of my Z headlights
here's what we did to my buddy's STi
and here's how i did the cobalt headlights
it was a good idea in theory by Merc, but only would be successful to get out any initial moisture in the headlights from when they were opened and any humidity got into them. if he has a leak, he may run into a problem in the future when the dessicant becomes saturated.
Yeah he did say he had a leak and the silica became saturated. This is all under the assumption that the lights are sealed of course. If tehy are not you are SOL. A pressure test would be a good way to check I suppose. Hook up a compressor and put some water along the seams to look for bubbles as air pressure builds.
the thing that sucks about mine is when the headlights are installed you can see the glue in the gaps of the fender and hood.. i also broke a few of the plastics off so that looks ghetto. I'm thinking about getting fiberglass and putting that around my headlight then sanding it down and painting the back of the light to make it a lot nicer??
my girls dad owns a bodyshop, he told me that when he sees condensation in a headlight his soluting is to drill a small hole at the bottom of each headlight. I donnu about this however, what do you guys think.
Dude that looks pretty damn good.....wish I never sold mine
