I whole new take on skyline tail light mod!
sorry guys, been busy. ha ha, got the inner tails done. ill get progress up asap. royce if u shoot me a set of tails ill fab u somethin up. updates posted on first poist!
Here is my take. I made 4 led rings for the markers and and separate superflux LEDs in a cross hair formation as the stop and turn signals
a short video of them in action
YouTube - Cobalt SS Supercharged LED Tail lights
To open my tails I just used a heat gun about a foot away moving it slowly around the light, aimed right at the glue. It just pries apart after a few minutes. Somebody should attempt this:
http://www.youtube.com/watch?v=A5avSb7xNnE
I'm thinking about it... but I need to find some really bright **** to replace my inner rings for this to be feasible. I'd wire it so that during the day the outers are the brake lights, like normal.
There's this blk sealant stuff that sticks on... everything... everything... an it's a bitch to get off, really gooey, an sticky... so jus.. watch it?
but yea, blowdryer, an the same as headlights... watt I did was use a knife/screwdriver/sharpish skinny object, an go around the taillight between the crevices, like you're cutting somethin..
There's a grey layer of..silicone/sealant?.. between the outer an inner layer of the taillight, the part you wanna be careful with is the part where it goes up like a triangle(one on both sides) they're easy to break, but if you wanna use you're own sealant, then jus chop em up an take em out(much easier)
Sealin em up tho... was a beeeeeeech
I used the stock grey layer so afterwards, I heated everything up put some glass sealant between the cracks, gathered up as much of that blk gunk as I could
so if you got some inner tails, or a whole set for cheap... get at me
ha I thought selaing them was the easiest. and I've actually been talking to cobaltss/tc about doin my tails just like the last video posted. ha ha. you'll ahve to ask him I've been so excited about doin it that's all he's heard about!! ha ha. I'll take pics tonight guys when I get my tails done. now keep in mind I wont have a relay yet so you're gonna see some super blink. ha ha
exactly.. i have hyper flash...sometimes.. its mostly when my car wants to lol im pretty sure its jus a shoddy connection somewhere.. jus get some resistors an/or a good relay
they flash really fast because there is no load on the relay, which is actually part of the bcm which means either a relay is needed or a load resistor. so I gotta figure out exactly how to put enough load on the line to keep the hyper flash down.
You could wire 100 relays in series and still have hyper flash. But you're on the right path with resistors. We don't even have flashers... ever notice the clicking sound of your turn signal is a poorly replicated attempt at a clicking sound by your BCM and it comes out of the driver's side speaker?
if the LEDs connected all the way around it'd be 85x better tho
