Inner tailights
Old Aug 13, 2009 | 02:33 PM
LTBALTBMX's Avatar
Inner tailights
How should I go about cracking them open so I can put LED's in them? I'm afraid heat might warp the plastic.
Old Aug 13, 2009 | 06:59 PM
JoshuaVnyrd1817's Avatar
How to section.
Old Aug 13, 2009 | 07:01 PM
dunit121's Avatar
just dont head them up too much
i dont think they will withstand as much head as headlights either so be carefull
Old Aug 13, 2009 | 09:52 PM
LTBALTBMX's Avatar
I'm a bit scared about using a drill also. Is there a sure fire way?
Old Aug 14, 2009 | 02:30 AM
NCC-2000's Avatar
What do you need a drill for? Just get some LED strips from Oznium.com and use a hair dryer to heat up the glue and a screwdriver to pry it out. You end up with this:
Old Aug 14, 2009 | 11:15 AM
Shez's Avatar
^^ That looks so good.
Old Aug 14, 2009 | 08:29 PM
LTBALTBMX's Avatar
Hairdryer eh? And you're sure that won't warp the lights?
Old Aug 14, 2009 | 08:51 PM
NCC-2000's Avatar
I got mine pretty hot to soften the glue enough and they're fine.
Old Aug 15, 2009 | 06:41 AM
Sweetsandman's Avatar
NCC-2000, are those aftermarket tail lights or did you just get multi-LED replacement bulbs?
Old Aug 15, 2009 | 10:21 AM
NCC-2000's Avatar
If you mean the outer lights, they're from eBay.
Old Aug 15, 2009 | 09:46 PM
LTBALTBMX's Avatar
I don't know what your secret is but the sealant is tough as can be! I heated the white stuff up pretty good with a hair dryer but a screw driver still fails to pry it out.
P.S. Tell me your secret!
Old Aug 16, 2009 | 07:39 AM
NCC-2000's Avatar
Don't use a normal size screwdriver. I used a small flat head I had laying around, when the glue is hot enough to get just a tad softer, the smaller screwdriver should be able to poke into it enough to start prying it out. It's very tedious, and you'll want to throw the lights across the room after like 10 minutes, but it can be done.
Old Aug 16, 2009 | 11:40 AM
LTBALTBMX's Avatar
I used a jeweller's screwdriver. Did you remove the black gasket also? The adhesive is ******* gross...
Old Aug 16, 2009 | 04:00 PM
NCC-2000's Avatar
Yeah that gasket comes off too. I'd use something a little stronger than a jeweller's screwdriver just so you don't end up bending the **** out of it.
Delta2.2
Dec 3, 2008 08:37 PM
ICEMAN187
Oct 15, 2007 03:53 PM
WhiteSSBalt
Oct 9, 2007 08:35 PM
WhiteSSBalt
Jul 6, 2007 11:41 AM
WhiteSSBalt
May 9, 2007 04:31 PM
