Official Plasti Dip Thread?
Old Mar 9, 2014 | 05:50 PM
  #601
BlackielawlessSS's Avatar
That looks dirty, in a good way
Old Mar 9, 2014 | 06:58 PM
  #602
MM06balt's Avatar
Originally Posted by S13Hero
So much win
Old Mar 9, 2014 | 09:37 PM
  #603
cobaltsssc760's Avatar
Ask and you shall receive haha. Sadly this is in my shop. The color pops so much more in the sunlight. Come spring when it sees day light I'll have better pics haha. I picked up my wheels. Can't wait to do them!
what dip colors did you use to make this color?
Old Mar 9, 2014 | 10:13 PM
  #604
I am still do to do my top.
Old Mar 9, 2014 | 10:26 PM
  #605
MaxDugas's Avatar
Better pictures. I'm pretty satisfied.
Really nice result! Thats a clean sedan you have there!
Old Mar 9, 2014 | 10:48 PM
  #606
Should have shot some glossifier over them. I did and my gold rims look great, and not flat.
Old Mar 10, 2014 | 01:47 PM
  #607
KTM's Avatar
KTM
Looks great, not sure yet what I want. Everyone at work said to go black. But idk, that Teal looks sweet.
Sent from my LGL86C using CobaltSS
Old Mar 10, 2014 | 02:02 PM
  #608
i KNEW i should have gone with teal
Old Mar 10, 2014 | 02:50 PM
  #609
Your wheels are sick!
Old Mar 10, 2014 | 02:53 PM
  #610
i hope they look dope as that
Old Mar 10, 2014 | 02:54 PM
  #611
I bet they do. My wheels were that color before.
Old Mar 10, 2014 | 03:55 PM
  #612
So I have decided to take the plunge and will be purchasing the whole car kit from the website and was wondering what exactly I should purchase to dip the entire car pearl white. I want to use the white pearl powder but am unsure of how exactly to go about it. I will purchase the grey as a base coat due to the websites recommendations. Does anyone know if I can get a good enough base coat from only a gallon of grey or will I need two? Also when it comes to the white pearl do I need to just purchase gallons of clear and glossifier, mix those and add the pearl white powder to that; or do I actually need to buy white dip as well? Im thinking 3-4 gallons total should be more then enough to do the entire car with good coverage. so am I looking at 2 gallons of clear and one glossifier gallon? or do I need to do one clear, one white, and one glossifier. this is the only thing I am confused about. any help would be greatly appreciated.
Old Mar 10, 2014 | 04:32 PM
  #613
iToastie's Avatar
I just emailed them the other day, it might help you.
For a base coat (depending on your car color for number of coats needed) you need 2 coats. Then the pearl color will be about 4-6 coats.
The pearl colors are purchased this way:
Clear gallons if plasti dip and you mix whatever pearls you want in.
If you mix pearl powders into an already existing color, it will be worthless and the pearl won't even show.
If you have a lighter color car, 2 coats of grey would be fine. If it's black or a blue, I'd go with an extra coat or two. The more dip, the easier to peel off later.
As to the number of gallons needed for everything, they need to know exactly what car. I haven't got around to emailing them back, what car I have. I guess I should.
From what I know... 3 gallons of normal dip will cover a Cobalt with about 5 or so coats.
I'd say a gallon of grey (if you have money to blow, I'd suggest 2 gallons), and 3 gallons of the clear dip for pearls.
Old Mar 10, 2014 | 10:37 PM
  #614
MM06balt's Avatar
^ this pretty much explains what you need to do.
Because I'm assuming you have a black car (sig) I'd recommend going with 1 gallon of the gray or black, maybe two just to be safe. You'd rather have it cost a tad more but peel easy, trust me..
Took me close to 4 gallons to cover my car (white originally) with proper coverage.
I've been fooling around with the new pigment colors from DYC on black base coats and they typically cover properly in 4-6 coats.
No idea how the white pearl will cover over a dark base but that's just something you'll have to play with.
Might not be a bad idea to goof around with some test samples before you make the big purchase, just to see what happens.
If you do wanna dive in head first though, I'd get two gallons of the gray or black for the base and then 1 gallon matte clear & 1 gallon glossifier.
Then, obviously you'll need your pearls. 100g total, 50g per gallon of clear.
The problem with getting 3 gallons of clear is that there is no way to 50/50 mix the matte clear and glossifier. You'd have to get 4 and that could get spendy..
But.. then again, you could just go ahead and order 4 (2 matte clear & 2 glossifier) and then use a little bit of each to run tests before you do the real thing on your car.
Old Mar 10, 2014 | 10:56 PM
  #615
Bluelightning's Avatar
Got Bewst?
Black and copper metalizer. If you do a couple light coats of the metalizer it is a dark bronze. The more coats you add the more copper it looks.
Old Mar 11, 2014 | 10:15 AM
  #616
It looks good.
Old Mar 11, 2014 | 11:00 AM
  #617
Pursuit_Gt's Avatar
Old Mar 11, 2014 | 12:48 PM
  #618
I don't think I have ever seen a g5 sedan around here.
Old Mar 11, 2014 | 03:15 PM
  #619
Pursuit_Gt's Avatar
Pursuit/G5 GT sedans were only sold in Canada I believe.
Old Mar 11, 2014 | 03:33 PM
  #620
Pretty cool looking!
Old Mar 11, 2014 | 03:34 PM
  #621
i like the flat black going along the side of the car
i don't think ive seen a g5 sedan either lol
Old Mar 11, 2014 | 04:56 PM
  #622
I wish gm had offered the lsj and lnf in the G5.
Old Mar 11, 2014 | 07:30 PM
  #623
C_A_D88's Avatar
^ same bloody cars just a diff front grill lol u want an LNf "g5" buy an LNf and slap a Pontiac grill on
Old Mar 11, 2014 | 08:23 PM
  #624
I know that! GM I feel dropped the ball.
Old Mar 11, 2014 | 09:16 PM
  #625
Thumbs up
I thought the ones sold in the states were called G5 GT sedans and in Canada they were called the Pursuit.
