Paint
Old Mar 13, 2012 | 01:44 PM
Corey V's Avatar
Paint
Hey I was wondering what kind of paint you guys used to paint your headlights or if you know of a good paint for plastic because I painted my headlights with Krylon for plastic and it sucked I did a bunch of really light coats and it ended up running and it kept splattering.
Old Mar 13, 2012 | 01:51 PM
Switt23's Avatar
One trick that helps if you are going to be using spray cans would be to fill your sink with Hot water and place the can in the water for a few minutes. Make sure the water is not extremely hot as too much pressure is bad, but if you can warm the paint up a little bit it will thin out when you shake the can.
This will make it so when you go to actually spray the paint it sprays smoother with less splattering.
Most people on the board would use spray paint and wet sand in between coats.
Old Mar 13, 2012 | 01:53 PM
MastaShaKe_88's Avatar
Ima try that next time I spray somethin!^^
I used some regular duplicolor stuff with all of mine... if you sand it, make sure you smooth it out real good before startin to paint
Old Mar 13, 2012 | 01:59 PM
07LSJ's Avatar
you got pics of how it came out? im looking to do mine soon.
Old Mar 13, 2012 | 02:10 PM
with duplicolor paint? Ima see if i can find some...
Old Mar 13, 2012 | 02:12 PM
but really you shouldn't even tint your headlights. my opinion isn't based on looks or speculation, i tried it with my old car. i couldn't see ****!
unless your really trying to just do a really light coat... then yea, just do what ^^^^^^are saying
Old Mar 13, 2012 | 02:16 PM
Corey V's Avatar
Sorry should have specified I meant painting the housings for my retrofit. Painting the lenses would just be a bad idea IMO
Old Mar 13, 2012 | 02:58 PM
Bluelightning's Avatar
Got Bewst?
I know it's a little more money but getting them painted with an actual paint gun is the way to go IMO. Looks so much better than rattle canned.
Old Mar 13, 2012 | 04:35 PM
LS6Rally's Avatar
ehh mine came out fine i think, no issues noticeable unless you were right infront of teh lense and looking for flaws.
i use Duplicolor Engine Paint. I dont want the heat from the HIDs to cause any flaking
Old Mar 13, 2012 | 08:47 PM
Corey V's Avatar
Ya I was trying to keep the price relatively cheap because I got q deal on the projectors and headlights...but I don't have access to a paint gun, Amy idea what a shop would charge
Old Mar 13, 2012 | 08:52 PM
N1ckateen's Avatar
flat paints are always easiest to work with. gloss paints you have to be a lot more careful and patient. always reccommend a fan tip as it's much more difficult to get overspray with one. be patient if you missed a spot get it on the next coat. you rush it's gonna look like crap. krylon seems to work very well for me and i've painted A LOT of stuff. several sets of rims, engine parts, many many many many MANY headlights. any questions don't hesitate to pm me i'll see if i can help. GL
Old Mar 13, 2012 | 10:39 PM
EmperorJJ1's Avatar
got mine sprayed in a paint booth out of a gun
chefhhr
Oct 26, 2015 10:36 PM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
camaromanss1992
Oct 1, 2015 10:51 PM
riceburner
Sep 26, 2015 12:57 AM
