Paint blemish help
Old Oct 14, 2005 | 10:47 AM
slowbalt's Avatar
Paint blemish help
Ok, so I removed the rear bowtie and it left some adhesive behind. I used a 3M adhisive remover made for cars and then the paint looked cloudy there. I tried cleaning the spot, nothing. I took some rubbing compound and used that then waxed the area, nothing. What else can I try or is my paint just fubar right there? I love the look of the clean ass end but if you catch it in the right light you can see the duller area. I am thinking of painting and putting the bowtie back on. Any help would be great!
Dan
Old Oct 14, 2005 | 11:05 AM
mkulrey13's Avatar
Yea mine did the same thing i just painted my bow tie and put it back on. I Auctally like it alot better. I rather not hide who makes my car kuz im not assamed!
Old Oct 14, 2005 | 11:40 AM
DMcGrew's Avatar
Should have used a hair dryer
Old Oct 16, 2005 | 11:51 AM
slowbalt's Avatar
used a heat gun didn't need the hair dryer. and I'm not assamed of chevy, its all I have ever owned and I have a bowtie tattoo on my sholder, I just like the clean look.
Old Oct 18, 2005 | 04:43 PM
drives2fast4u's Avatar
Have you tried wet sanding it yet? Can you tell if it's still in the clear coat?
Old Oct 18, 2005 | 06:47 PM
slowbalt's Avatar
I havn't wet sanded it. Thats a good idea! I used rubbing compound and it didn't touch it. How much further will wet sanding go?
Old Oct 18, 2005 | 08:03 PM
What rubbing compound did you use? 3M? Is there anyway you can post up a picture of the area? It would really help me to recommend what steps would be best to take.
Old Oct 18, 2005 | 08:19 PM
d_backer1's Avatar
Wet sand w/ 2000-2500 grit first to minimize clear removal then use perfect it III buffing compound can be bought @ most auto paint supply stores
Old Oct 18, 2005 | 10:44 PM
slowbalt's Avatar
Sounds good, will try that. Thanks a bunch!
Dan
Old Oct 27, 2005 | 11:17 AM
mkulrey13's Avatar
Slowbalt i had the same problem like i stated above but i have found a solution! I went to my local walmart and found Scratch out. Its in a bright yellow bottle. All ya do it clean teh area ya want to fix. buff it onto the area for about a min, let sit for about a 30 secs with a hair drire blowing on it then buff again, 30 sec hair drier, then buff then use a cloth and rub off. Do it a few times and it will be gone. I was amazed on how good it makes it. Awesome stuff!!
chefhhr
Oct 26, 2015 10:36 PM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
camaromanss1992
Oct 1, 2015 10:51 PM
riceburner
Sep 26, 2015 12:57 AM
