painting trim and pillars.. question..
What's the best way to get the trim and a/c pillars prepped to paint? I have the silver dash trim and I'm considering painting it gloss black.. I also want to paint the a/c pillars black to match the rest of the interior.. But the a-pillar that I have is the Cobalt Addiction triple pod, and it's pre-painted.. So what's the best way to go about doing that..? Should I just kinda rough everything up with a super high grit paper (both the trim and pillars) and then spray..? Or should I not even use sand paper..? Any help would be great.. Thanks!!
Honestly, for almost everything I've ever painted before, I have never used primer.. lol. And I rarely sand.. I did my front bow-tie without sanding, and it's held up great.. Do you think I'd be fine with using the thinner on the pillar, then just spraying it..? And for the trim, no need to sand, just clean real well and spray?
since the pillars have been painted before, its a good idea to remove the paint. After time it could start to peal off and/or you will have imperfections. I think its a good idea to use thinner to get it off....I use Krud Cutter Graffiti remover.....you can find this at wal-mart in the paint department. Its safe on any surface and works great. I never paint over old paint.....
Delta coupe
Sep 30, 2015 08:11 AM
