Projectors in stockers help - bad cutoff
I had Gen 4's and was unimpressed then moved to a retrofit where I put mini morimoto's in my stock headlights and all is great. I noticed however that just like with my Gen 4's the driver side cut off is less than adequate and slightly discolored. The passenger side is perfect and wide just like how it should be. I had morimoto 5000k bulbs in before and thought perhaps this was the problem so I swapped them for a set of Philips 4300k and same thing. Could this be a ballast issue? I am at my whits end on this. I dont want to have done a retrofit and not be reaping the full benefits of it.
Thanks
Thanks
I have seen this before. It has to do with where the focal point of the HID bulb is, inside the projector. Yours are probably pushed back just a little, which is why it's throwing the light off. If the base of the bulb is plastic, take a file and file down the locating nubs just a little bit at a time.
i know some of the morimoto's had issues with issues talk to the company you bought them from.. it also looks like hot spot isn't positioned on step up like it should be .. also.. you need to aim those lol
Iceberg
Sep 29, 2015 12:33 PM
