quick question about painting bowtie
Old Mar 15, 2009 | 11:49 AM
sscobalt205's Avatar
I am trying to remove the gold bowtie from the chrome so i can paint it easier. I heard using a heat gun works, but i don't own one. Would a hair dryer work? also does it just pop off or do u have to pry it open? let me know. thanks
Old Mar 15, 2009 | 11:55 AM
1badBlueberrySC's Avatar
I just took a small flathead screwdriver and pryed it apart.
2 coats of primer, 2 coats of paint, 1 coat of clear it's how I did mine and it's great!
hilty003's Avatar
the front one unscrews first. then i just used a screw driver to pry both off. just take your time wiht the screw driver.
Old Mar 15, 2009 | 12:09 PM
oh alright thanks. the screw driver won't damage it?
Last edited by sscobalt205; Mar 15, 2009 at 12:09 PM. Reason: Automerged Doublepost
Old Mar 15, 2009 | 12:12 PM
JsavageSS/TC's Avatar
If you are worried about damaging the bowtie you can always warm it up (i.e. heat gun, blow dryer, oven) BUT DON"T OVER HEAT, it could melt. I used my girl hair dryer on it just to warm up the 2 sided tape and it came off really easily
Old Mar 15, 2009 | 12:24 PM
alright. how long did you heat it?
Last edited by sscobalt205; Mar 15, 2009 at 12:24 PM. Reason: Automerged Doublepost
Old Mar 15, 2009 | 12:26 PM
lol, not sure, just heat for about 20 - 30 seconds and then attempt to pry it off, if its still hard then heat a little more
Old Mar 15, 2009 | 12:30 PM
ok i am getting it off, but....the chrome is definately bending...what should i do?
Old Mar 15, 2009 | 12:41 PM
hilty003's Avatar
which one are you taking off? the back im assuming...
Old Mar 15, 2009 | 12:42 PM
the front actually. i just got it to pop off, but some of the "chrome" i had to bend. atleast its on the bottom though...
Old Mar 15, 2009 | 12:44 PM
hilty003's Avatar
i tried to take the whole chrome and everything off the back then realized that was stupid and just took the gold piece off. get 2 lil flat heads and stick them between the chrome and gold and lightly pry. move to all sides and lift a little. i kinda kept moving in a circle around the bowtie as it started to loosen up.
yea you wont see much of the chrome on the bottom of the front so thats not a huge deal
Old Mar 15, 2009 | 12:48 PM
alright sweet. thank you. but you think i could bend it back a lil?
Old Mar 15, 2009 | 01:11 PM
heat it up, bend it back
Old Mar 15, 2009 | 02:50 PM
liljone's Avatar
hair dryer works too.
Old Mar 15, 2009 | 03:46 PM
alright sweet. I'm on my 4th coat!
Old Mar 15, 2009 | 03:51 PM
liljone's Avatar
of black or clear? IF black put on 4 more coats then 10 coats of clear and it will turn out like this:
Old Mar 26, 2009 | 05:39 AM
MannyP's Avatar
what about the krylon spray paint that says no need for primer is this bad to use on the bowtie just alone?
Old Mar 26, 2009 | 05:45 AM
liljone's Avatar
that is what I used for the black.
Old Mar 26, 2009 | 07:48 AM
hailcesar75's Avatar
i didnt even need to take it apart. i just taped of the chrome and painted. tiny bit of paint ended up on the chrome but i easily scrapped it off with my fingernail. twas easy for anyone else looking to do this
Old Mar 26, 2009 | 05:19 PM
MannyP's Avatar
it turned out really nice, you said you put 10 coats of clear coat on after the 4 coats of black?
Old Mar 26, 2009 | 05:23 PM
liljone's Avatar
IMO it easier just to tape it off. I tape mine it was fast and easy.
Old Mar 26, 2009 | 06:51 PM
X2 ^^^^
Old Mar 26, 2009 | 06:54 PM
BumbleBee's Avatar
YEah i just put some painters tape between the chrome and gold part. worked great.
Old Mar 26, 2009 | 08:46 PM
ExCaLdA's Avatar
plastidip ftw!
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
riceburner
Sep 26, 2015 12:57 AM
