Recaro seat swap
Old May 15, 2013 | 12:30 PM
Adams23's Avatar
Recaro seat swap
Ok so I have an 06 SS/SC and I just bought some recaros from the same year. Was wondering if they bolt right up and what else ill need to do
Old May 15, 2013 | 12:34 PM
CobaltVenomSS's Avatar
they bolt right up
Old May 15, 2013 | 12:39 PM
Adams23's Avatar
Sensors all hook up?
Old May 15, 2013 | 12:40 PM
LS6Rally's Avatar
yes, except some dont have the seatbelt sensor in teh passenger seat.
Old May 15, 2013 | 12:44 PM
Adams23's Avatar
Will that mess up anything?
Old May 15, 2013 | 12:50 PM
LS6Rally's Avatar
you pass side airbag will not read the weight sensor and the service airbag alarm will pop up on the DIC. you can take the sensor out of your current seats and put it in the recaro.
Old May 15, 2013 | 03:25 PM
Adams23's Avatar
Where's the sensor located
Old May 15, 2013 | 03:36 PM
under the seat (if its even there)
just look under your passenger seat for plugs. if its plugged up to anything then you have a sensor to swap over. unless you have heated seats then that may be what the plug is for.
to take the seat out, push the seat all the way forward, there are two 18mm bolts holding the framerails onto the carpet, once those are out you lean the seat forward then it pops right out.
Old May 15, 2013 | 03:45 PM
Adams23's Avatar
Ok cool thanks bud, is the sensor hard to swap?
Old May 15, 2013 | 03:46 PM
Gelladuga69's Avatar
You have an 06 SC? No passenger sensor.
Driver seatbelt should/could be in the driver recaro seat already.
Old May 15, 2013 | 03:49 PM
i swapped the whole kit and caboodle once from tc seat to tc seat and it was easy, just take off and put on the other seat. but yeah if its an 06 i'm fairly confident you will have no sensor to worry about; mine had none. now i'm rockin teh ricardo's!
are you also switching the backseats? what interior colors do you have currently?
Old May 15, 2013 | 04:02 PM
Adams23's Avatar
Thanks guys and this is why I love this site, straight answers and no bs!
Old May 16, 2013 | 06:44 PM
Adams23's Avatar
seats i got dude had welded them in a civic hatch and turns out he cut the bottom part on the front of rails so i had to swap rails from old seats. 5 minute job turned into an hour for one seat. swapping passenger rails tonight. ******* dumbasses i tell you
Old May 16, 2013 | 07:07 PM
Haha that sucks well atleast ur gettin them to work!
dennis69
Oct 20, 2015 04:49 PM
ThoR294
Oct 4, 2015 08:44 PM
ThoR294
Sep 28, 2015 05:31 PM
