Retrofit Install Problems
Finally got some time to install my retro headlights today and i've run into some problems. First one is that my halos dont work. The second is that when I turn on my high beams they blow a fuse and neither will work. This is my first time wiring stuff like this so maybe i just messed up but any help would be appreciated. I got the H1 mini kit from TheRetrofitSource and well as the Halo kit
Spoind like messed up wiring to me. Assuming you have a relay harness everything should be pretty much plug and play except the halos. Make sure you have the inverter box for the halos plugged in, and try testing them directly to the battery
correct, you need to swap around 2 wires on the relay harness side of the blue connector. I think it's the white and blue wire but I don't remember exactly what colors they use anymore.
