Reverse/License plate LED bulbs
Actually, I just plugged them in and they work. They flash faster than normal, as if a bulb were out but they do flash. I had someone try and help me with connecting the resistors, but we couldn't get them to work right so I never installed them. Just running it the way it is.
The resistors just need to be connected to a ground and the proper positive wires for the light you want to fix. For the front signals, if I remember right, you just need to splice into a ground and the blue wires that feed the signal lights, not the parking lights. I don't know which wire to splice into on the rear lights since my tail lights came with a balancer built into them so I had no splicing needed back there.
should be direct inline with the power wire
hit me up with what u did and maybe i can help out
agentirons
Oct 16, 2015 02:11 AM
z28addiction
Sep 28, 2015 12:03 AM
