side door molding?
Old Feb 24, 2007 | 11:57 AM
mattmatt's Avatar
side door molding?
i got them off no prob , i got most of the glue off but u can still see a thin layer of it left is there any way i can get that off besides using a blade
Old Feb 24, 2007 | 12:06 PM
kenhebe's Avatar
We have to remove these all the time at my body shop. Do not use a razor blade. You will have to get a hold of what's known as an "eraser wheel" 3M makes it. You can probably get one at an autoparts store. It is a rubber wheel that attatches to the end of a drill and "erases" the double sided tape. It does not harm the paint as long as the molding were not applied to the car within 24 hours of it being painted and as long as you don't spin the drill as fast as it can go. The wheel works best at a moderate speed. If you go too fast, the wheel gets hot and causes the tape to melt on to the car. So just use your head when doing it.
Hope that helps.
Old Feb 24, 2007 | 12:10 PM
FuzzzMan's Avatar
Can't you just use somthing like "Goo Gon" or "Goof Off" both products that I believe you can get from your local wall mart
Old Feb 24, 2007 | 12:17 PM
rally's Avatar
Goo Gone is the way to do it
Old Feb 24, 2007 | 12:26 PM
xspyder85x's Avatar
what he said.
Old Feb 24, 2007 | 12:32 PM
kenhebe's Avatar
I do not reccomend that because they are chemically abrasive. Appearence wise it might work, but they damage the clear coat in the areas that it is applied. You won't see any problems right off the bat, but after about 2 years you will see dull spots.
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
