So PISSED on eyelids
Old Nov 30, 2007 | 01:55 AM
deuce's Avatar
Well, i bought 2 cans of GM paint so i could do my headlights, eyelids... anyway i masked it off sprayed it, cleared it, went to take it off the next day and it peeled right off like a cheap sticker. WHAT THE ****!??? i didnt think i had to sand my lights to get it to stick. how did everyone do theirs? it didnt stick at all. do i have to sand before i spray the lights? the how to didnt show any sanding. what the hell is up, i spent 30.00 and 2 days of my time to do this, and its for nothing.
Old Nov 30, 2007 | 01:57 AM
rguti153's Avatar
have no clue ......thinking of doing the same with my lights
Old Nov 30, 2007 | 02:02 AM
saunders1986's Avatar
you have to sand. paint wont stick if the surface isnt ruff
KillerBee's Avatar
use a fine sandpaper and sand the headlights maybe use a can of plastic primer on them
Old Nov 30, 2007 | 02:10 AM
LS6Rally's Avatar
yea 400 grit
Old Nov 30, 2007 | 02:12 AM
JRelly's Avatar
I wouldnt use 400 grit, I say 800 should do just fine, you dont need to sand much
Old Nov 30, 2007 | 02:25 AM
ssbalt06's Avatar
i think it might just be the plastic. i have the same cans of paint and i read them over and over again and i forgot that it is "touch up" paint yanno. therefor mainly used for metals aka the body.
Old Nov 30, 2007 | 02:33 AM
JRelly's Avatar
Yea but that paint will work fine on any surface if its prepped properly. With some light sanding he should have no problems
Old Nov 30, 2007 | 12:34 PM
X GEOFF X's Avatar
**** i wish i knew that when i did my eye lids, they started chipping away from the front back slowly over time. look like **** now, but as an on-campus college student i dont use my car much nor do i have access to spraypaint and stuff atm.
Old Nov 30, 2007 | 12:40 PM
Cobalt_SSTuner's Avatar
or you could first put down a coat of primer...then use paint...
and once your done painting, take the tape off, and let it dry.
Last edited by Cobalt_SSTuner; Nov 30, 2007 at 12:40 PM. Reason: Automerged Doublepost
Old Nov 30, 2007 | 12:44 PM
SmOKe JeNsOn's Avatar
I didnt sand mine at all. I just put 4 or 5 coats of paint and 4 coats of clear I just dont spary the water directly on the headlights when i wash it. Had it for about 3 mnths now I believe Pics are in my garage
Old Nov 30, 2007 | 02:47 PM
th0ughtless's Avatar
I did the same, and no problems for me. You should peel the tape off when the paint is still kinda tacky, so it'll be able to come apart smoothly and stick to the plastic. If you didn't tear up the edges too much, try using pieces of black pin striping to make the edge look better.
Old Nov 30, 2007 | 02:48 PM
chevysalesman614's Avatar
100% correct.
Old Nov 30, 2007 | 02:51 PM
cblt12's Avatar
that is exactly how i did mine and they were perfect for over a year. no chipping at all and no sanding.
Old Nov 30, 2007 | 04:10 PM
ecotecon18s's Avatar
adhesion promoter ftmfw!!!
Old Dec 1, 2007 | 03:08 PM
deuce's Avatar
whats that?
Old Dec 1, 2007 | 03:14 PM
Swan SS's Avatar
i would go the light sanding route, then i used self etching primer, GM match paint and finally clear coated... and the turned out awesome.
Old Dec 1, 2007 | 03:18 PM
Black07LS's Avatar
Originally Posted by SSuperchargd
whats that?
It helps paint stick to plastic. You can get it at Lowe's
Old Dec 1, 2007 | 03:30 PM
an0malous's Avatar
sanding + adhesion promotor.
that headlight plastic is WAY to smooth for paint to stick to.
btw, dont wait to take tape off,
the paint is connected on your tape, to the paint on your headlight, and if you allow that to cure, it wont *break* cleanly.
you need to remove any taping as soon as possible.
a razorblade can help keep the line even cleaner.
Old Dec 1, 2007 | 05:06 PM
you dont need to sand if you you a primer. the primer will stick to the plastic as long as you do it in light coats. then once you get a few light coats of primer down, then use your paint and your clear coat. Once you do your last coat of clear, take the tape off right away.
Old Dec 2, 2007 | 03:04 AM
ssbalt06's Avatar
^ i painted my eyelids right on to the plastic and they looked and stuck perfect?
Bluelightning
Nov 11, 2015 02:41 PM
Tupp
Sep 30, 2015 08:18 PM
NightmareSS
Sep 30, 2005 09:42 AM
mcphatty
Aug 2, 2005 03:56 PM
