Spray painting calipers
Old Jun 17, 2009 | 05:56 PM
ohshitz's Avatar
I went out and bought some red spray paint from an auto shop near where I live, not sure if it's victory red like my car, but figured it wouldn't matter if it's not exactly the same color. I have an 05 and my calipers have never been cleaned. There's lots of dirt/break dust on them as you can imagine, which I can forsee as being hell to clean. Any suggestions on cleaning products/methods I should use? Also, I didn't want to have to remove the caliper from the rotor, I was planning on spray painting them while on the rotors and just covering the immediate area. Any suggestions for a person who's a newbie with this sort of thing?
Old Jun 17, 2009 | 08:42 PM
haymakercobalt's Avatar
You can buy brake cleaner at autostores. That would be the best bet. You might also want to sand down your calipers with 400 grit sandpaper.
Old Jun 17, 2009 | 08:58 PM
Red07SSNA's Avatar
Might want to consider using a caliper paint -- or even an engine paint. These withstand up to 500 degrees.
If you use normal paint the heat may burn it, mar it, or make it look darker.
Old Jun 17, 2009 | 09:23 PM
ohshitz's Avatar
sorry for the lack of detail- I bought red caliper paint!
would that require removing the caliper? What is the purpose of sanding the caliper down, to smooth it out? Thanks for the advice! (I just bought the vinyl cobalt lettering that goes on the calipers from the grafix website.. I'm hoping it will look good!
Old Jun 17, 2009 | 09:37 PM
You can clean the caliper with it still attached to the car. And the point of sanding the metal is to smooth it out and help give the paint a better surface to adhear to.
Old Jun 17, 2009 | 09:39 PM
BLAZIN07SS's Avatar
I'm too JDM for you
dont sand it, waste of time. clean it, dry it, paint it. the surface is rough enough that the paint will stick good
Old Jun 18, 2009 | 12:03 AM
80vetteL82's Avatar
I just finished mine today. My car was only a year old, but with New england's winter my rear calipers were pretty dirty. With a wire brush, 320grit sand paper, and a can of brake cleaner I got them nice and shiny. I got 2 cans of paint and put about 4-5 coats on each caliper. They came out great.
I would recommend sanding them but thats up to you.
What do you guys think about clear coating the calipers after painting? Is there any point?
Old Jun 18, 2009 | 01:31 AM
slobalt08's Avatar
For calipers needing a repaint, they should be sanded correct? Sorry for the thread jack. Figured it was easier than creating a whole new topic for one small question.
Old Jun 18, 2009 | 01:36 AM
Tazman89's Avatar
yeah you should sand them if your gonna repaint them.
Old Jun 18, 2009 | 01:57 AM
slobalt08's Avatar
Alright thanks. Also any specific grit?
Old Jun 18, 2009 | 07:51 AM
redline4's Avatar
a lower grit sandpaper like 300-400 grit.
Old Jun 18, 2009 | 09:43 AM
blaSSt's Avatar
Clear will help level the paint and should make them look better. Mine are cleared and the vinyl is under the clear.
Old Jun 18, 2009 | 10:42 AM
ohshitz's Avatar
those look really nice man! I like the cobalt vinyl- ordered from grafix.com? I think the only part i'm worried about is getting paint on the rotors/the area around the calipers..I guess the best way to avoid that is by covering the entire area really carefully. I'll definately have to sand the calipers as well as use the brake cleaner.. my coblat is an 05 and the calipers have NEVER been cleaned.. I was looking at them today and they don't seem like they're rusty, except for maybe the front calipers having a bit of rust on them. Just a lot of dust and dirt.. which will probably end up taking the longest once I do paint my calipers. I'm looking forward to painting them though, in my opinion it's probably one of the best looking modifications you can do to your car at a cheap $ cost! thanks for all the advice posted guys, really appreciate it!
Old Jun 18, 2009 | 01:14 PM
80vetteL82's Avatar
Its going to be tough not to mask of the rotor with the caliper still on, but you should be able to do it. Personally, I took my calipers off. I think its better that way, I didnt want to risk getting paint on the pads or caliper pistons, so I took the pads out, taped up the pistons and ebrake. Then I masked off the entire wheel well area. I have pictures Ill post up when I get a chance.
what did you use for clear? My paint is perfectly smooth, but its been a couple days since I paint it but if I touch it with a little pressure I can put my finger prints in it still. Will that eventually harden? Or would a clear coat help that?
Last edited by 80vetteL82; Jun 18, 2009 at 01:14 PM. Reason: Automerged Doublepost
Old Jun 18, 2009 | 02:04 PM
blaSSt's Avatar
Friend of mine who owns a body shop did them, so I can't answer directly. It depends on your weather (temp & Humidity), what paint you used, etc. But it will harden with time. It can take a long time to fully harden, like 30 days in the poorest conditions. Sorry if that doesn't help much.
Clear coat is paint without the pigments. Ultimately it will dry also, but the hardner blend depends again on the weather...
Old Jun 18, 2009 | 02:08 PM
80vetteL82's Avatar
Yah thats what I thought. I think Im going to get plasti-kote clear coat for engines. Seems like that would be the best option because it is high temp resistant. Im going to wait until my new brembo decals get here so I can clear over those.
Old Jun 18, 2009 | 04:35 PM
ohshitz's Avatar
driver's side front rotor
sorry this is the driver's side front rotor.. the previous picture is the passenger side front rotor!
new mats
just recently installed k&n intake
this is why my account name is 'ohshitz' ..unfortunately someone reported it and it's been gone for about 2 years
Old Jun 18, 2009 | 11:54 PM
CobaltSS89's Avatar
yeah i did my calipers well the front ones and thats just spraying them thats it cause i was in a hurry lol, but im about to re do them and this time sand them down, what grit should i start off with? and last time i used the red caliper paint and it does work pretty good as long as you build paint up lol, but i think im going to sand it down next to make it a ton better!!! but so my questions are.. what grit sand paper should i use? whats the best way to make it look the best?
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
DANRICKARD
Oct 1, 2015 12:08 AM
riceburner
Sep 26, 2015 12:57 AM
