Is there a way to adjust our hood?
What's up guys I noticed on my car there the other day, on my passenger side from the god to the fender there is very little gap, and then on my drivers side hood to fender there is about a little less then 1/4 inch gasp.
Now is there a way to adjust it to move the hood more to the drivers side to close the gap?
Thanks guys!
Thanks guys!
You can take the bolts loose where the hood mounts in the back and try to shift the hood to the driver side, then tighten the bolts down. You will get a little bit of play to work with, but not a ton.
Hmm so I could loosen the bolts on the fender in the engine bay and try to push it in more? You think that would work? And with the hood should I unbolt both mounting points?
The Rookie24
Sep 20, 2015 04:33 PM
