Trim painting help....
Old Aug 9, 2011 | 10:06 PM
Burninrubber's Avatar
I need a lil direction from some of our more senior painters.... I painted my trim metallic blue. All the pieces turned out fine except the passenger dash piece. It was good but jusrt a lil dark in spots where it went on wet..... I tried sanding and repainting....no joy... i decided to take some ultimate goo gone and get rid of all the paint....i did and now the piece is down to the stock primer... Some of the primer coats keep getting knicked and im forced to sand or just keep removing....i stopped at a point where it wasnt bad..... I got some deep scratches in the primer.... Im wondering if i should keep sanding down the primer or keep removing layer after layer untill it is smooth with the goo gone.... Any types....... Or if i should fill the cracks with something and sand, and if so what do i use? Im at a stand still right now....any help would be appreciated.
Old Aug 9, 2011 | 10:12 PM
BlackARCA06's Avatar
Just sand the piece with 320-400. Then if you can re prime them. Im a auto body tech and always prime my work after im done to fill small imperfections then sand it smooth. But in your case I would just suggest sanding the piece down with 320-400 till its smooth. The paint will cover the 320-400 stratches as well.
Old Aug 9, 2011 | 10:15 PM
DiabeticKripple's Avatar
get some high build primer
Old Aug 9, 2011 | 10:22 PM
darkdarr's Avatar
yea i did my trim in tin sports coat red and i messed the right steering wheel piece up and i ended up putting like 10 coats of primer on it (sand then prime then repeat)
just take your time and it will come out good
Old Aug 9, 2011 | 10:25 PM
sweet. thats what ive been doing.... ill keep goin in that direction. Thanks guys.
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
Delta coupe
Sep 30, 2015 08:11 AM
riceburner
Sep 26, 2015 12:57 AM
