Two 10 inch Subs in the back?
Old Oct 27, 2005 | 04:43 PM
Nickc84's Avatar
Prolly a Stupid question but is it possible to add a nother 10 in sub on the other side in the tunk?
Old Oct 27, 2005 | 04:45 PM
PatDamanCobalt's Avatar
not directly across from each other.
cvenom2122's Avatar
Thumbs up
im not sure ut i think that pioneer sub box is made for left side only would look nice thoe
Old Oct 27, 2005 | 04:49 PM
p7x's Avatar
p7x
I was thinking of doing that. Why wouldn't another sub work???
Old Oct 27, 2005 | 05:03 PM
In theory, depending on the amp specs, which im not sure of you could run two subs. But running two subs face to face usually cause cancellation of signal. However if u took the pioneer out of its box and made a custom box it would work.
Old Oct 27, 2005 | 10:42 PM
averagewhiteboy's Avatar
I have the OEM Pioneer sub with amp, as well as 2 Inifiny 10's in a custom box in the back of my trunk with a seperate Pioneer amp. It seems t owork just fine. I was wondering about that though. Having it be "complete" with both on both side. Good theory...but you might need to fabricate something new...or just use a normal box.
Old Oct 27, 2005 | 10:52 PM
dimeo09's Avatar
wrong, i have another single sub across from my pioneer in a box and i sounds sweet
Old Oct 27, 2005 | 11:00 PM
Not completely...do some research.
Old Oct 28, 2005 | 12:32 AM
dimeo09's Avatar
I DID, i put another sub across from my pioneer and it def its mad hard no cancelation here my friend
Old Oct 28, 2005 | 12:52 AM
GotBoost?'s Avatar
You cant get one mounted on the other side because of the gas tank. if you look at the ss in the trunk, bows out where the gas tanks is. I already looked. you can get another one in a regular box but not the same stock box. Plus they dont make right side ones.
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 20, 2015 09:56 PM
z28addiction
Sep 28, 2015 12:03 AM
c_m_shooter
Sep 27, 2015 04:40 PM
