v-led switchbacks
v-led switchbacks
so i just installed my resistors on my switch backs today, one works fine , but i was wondering if you can install them backwards, as one of my switchbacks when i put the signal on the white stays on dimmly when the other side doesnt
could i have tapped into the wrong ground wire or installed the resistor backwards, or is it just the switchback itsself?
anyone else have this problem?
the one side works fine so i dont get it?
You have the resistor backwards on the one side. Switch the wires coming from the resistor on the bulb wiring and it should work. Black is ground. Blue is the turn on the right signal and i believe the left is yellow. Haven't had mine apart in a while.
yes..thanks...thats how i have it ..
its works how its hokked up now i hve no fast flash but the one side when the signal is turned on the white will stay on dimly while on the other side this does not happen
v-leds.com= A+ customer service
replacement is in the mail
open package
remove new switchback
replace with defective one
package back up
mark as refused return to sender
done
pretty good in my books
open package
package back up
done
