v-led switchbacks
Old Feb 19, 2011 | 09:57 PM
C_A_D88's Avatar
v-led switchbacks
so i just installed my resistors on my switch backs today, one works fine , but i was wondering if you can install them backwards, as one of my switchbacks when i put the signal on the white stays on dimmly when the other side doesnt
could i have tapped into the wrong ground wire or installed the resistor backwards, or is it just the switchback itsself?
anyone else have this problem?
the one side works fine so i dont get it?
Old Feb 20, 2011 | 09:33 AM
C_A_D88's Avatar
bump, i wanna fix these today but need to know what the issue is
Old Feb 20, 2011 | 09:42 AM
Xmetalhead2003X's Avatar
You have the resistor backwards on the one side. Switch the wires coming from the resistor on the bulb wiring and it should work. Black is ground. Blue is the turn on the right signal and i believe the left is yellow. Haven't had mine apart in a while.
Old Feb 20, 2011 | 10:18 AM
C_A_D88's Avatar
ok its just the resisitor both wires are black so i had no idea whether or not i could install it backwards or not but ill try it out today and see what happens
Old Feb 20, 2011 | 10:19 AM
C_A_D88's Avatar
and on both my turn signals the turn signal wire is blue
Old Feb 20, 2011 | 12:32 PM
Cobalt08LS's Avatar
splice one end of the resistor to the black (ground wire of the headlight harness) than splice the other end to the turnsignal wire which is blue
Old Feb 20, 2011 | 01:14 PM
C_A_D88's Avatar
yes..thanks...thats how i have it ..
its works how its hokked up now i hve no fast flash but the one side when the signal is turned on the white will stay on dimly while on the other side this does not happen
Old Feb 20, 2011 | 01:36 PM
NCC-2000's Avatar
Swap the bulbs from right to left, see if the problem follows the bulb, if it does, the bulb is at fault, if it doesn't, the wiring is at fault.
Old Feb 20, 2011 | 01:39 PM
C_A_D88's Avatar
sounds like a plan, thnx man.
Old Feb 23, 2011 | 05:23 PM
C_A_D88's Avatar
so the issue follws the bulb
Old Feb 23, 2011 | 09:34 PM
C_A_D88's Avatar
v-leds.com= A+ customer service
replacement is in the mail
open package
remove new switchback
replace with defective one
package back up
mark as refused return to sender
done
pretty good in my books
serega12
Aug 4, 2014 10:37 AM
hook
Apr 25, 2014 12:02 PM
drumrush
Mar 12, 2012 11:31 AM
blazinraign
Jun 9, 2011 10:00 AM
chitala383
Apr 16, 2010 05:35 PM
