wet hid ballast
Old Jul 19, 2010 | 12:13 AM
m1ke495's Avatar
wet hid ballast
fixable or s.o.l? it just happen, their now out of my car and drying, will they work again?
Old Jul 19, 2010 | 12:17 AM
ls1fbody's Avatar
Haz l33t wheelz.
how did you get it wet?
Mine get wet all the time, but there are rubber grommets to keep water out of the connections...
Old Jul 19, 2010 | 12:19 AM
trevor151's Avatar
i would say you should be fine. mine get wet every time it rains or when i wash my car. i have mine tucked underneath the headlight bracket so its harder for water to reach it though
Old Jul 19, 2010 | 12:41 AM
m1ke495's Avatar
i honestly dont know... they have been in for about 3 months and been fine. but i just drop back to my school and half way through the drive they went out.... i shut my car off for about 5 min,, turned the car on, and the drivers side comes on a little bit, flickers and then goes out the passenger side, nothing.
maybe its somthing elses? because all the seals were tight when i took them off?
Old Jul 19, 2010 | 12:44 AM
arman14's Avatar
Must be something else...
Try switching the bulbs
Old Jul 19, 2010 | 12:51 AM
m1ke495's Avatar
the bulb comes on tho?
Old Jul 19, 2010 | 12:55 AM
arman14's Avatar
Only the drivers side but then goes out right?
Old Jul 19, 2010 | 01:02 AM
m1ke495's Avatar
^^^ yeah it struggles then goes out
Old Jul 19, 2010 | 03:10 AM
slapbetcommissioner's Avatar
I had an issue my first day installed where my passenger light went out ( it was pouring rain all day) I was worried this would be an issue everytime.
Upon further investigation i realized the balast fell out from under the headlight bracket due to me being lazy and sticking it down with a double sided foam pad that I had stuck down and decided wasn't centers enough and moved over. Needless to say it didn't stick and i was to blame. The headlight went out because the cord from the headlight to the ballast wasn't sealed due to it hanging and getting soaked. I feared the balast was completely screwed and got creative. I put it in a bowl of regular white rice and made sure it was right in the connector that got soaked. I pulled it out and blew out all the rice that was getting sticky every 45 mins and then left it over night. It was good as new in the morning and worked great. I've since taken precautions to make sure that can't happen again and since been through many rain storms and no issues. Wet ballasts can be saved if it's an issue
Old Jul 19, 2010 | 08:23 AM
TommyP's Avatar
AWD > FWD
Are you running relays? A wet relay will cause problems much easier then a wet ballast. Ballasts are ok to get wet. I've had tue same ballasts for almost a year and they get wet all the time, no problems. I have had a wet relay cause problems though.
Old Jul 19, 2010 | 08:40 AM
iboost's Avatar
Mine got wet...actually filled with water. I took the ballast out and took it apart. The circuit boards were covered with like a a rubber coating. I dumped the water out and dryed them off with my gf's hairdryer and it was good to go
Old Jul 19, 2010 | 08:45 AM
mkulrey13's Avatar
99% of ballasts are waterproof. If you have warranty use it!
Old Jul 19, 2010 | 04:37 PM
m1ke495's Avatar
i dont want to sound stupid, but idk. when i turn on the car the lights turn on, there on like auto on all the time... welll until last night
Old Jul 19, 2010 | 10:14 PM
Mindrot's Avatar
Mine get pissed on all of the time. They should be water proof. Unless of course they're garbage off of ebay
Old Jul 19, 2010 | 11:26 PM
m1ke495's Avatar
its a legit hid kit, but now i have no idea whats wrong. i pluged them in today and nothing worked. could it be a fuse? or something else? i have the first gen housing (crappiest headlights ever made) and ive just been having problems with them, and now they wont come one,, any ideas??
bigdeertz
Nov 17, 2016 09:41 AM
chefhhr
Oct 26, 2015 10:36 PM
How to Guide
57
Oct 15, 2015 11:56 AM
Tupp
Sep 29, 2015 11:07 PM
dieGone
Sep 23, 2015 10:20 AM
