Whelen Hideaway help
Old Sep 16, 2008 | 11:58 AM
Coblt ss super's Avatar
Has anyone here installed a system in a car before? i have the 90 watt power supply with 6 outlets, it says to use wire that can take 125% of the power needed for the power supply. What kinda wire should i use?
Old Sep 16, 2008 | 12:12 PM
deuce's Avatar
a thick wire for the main line, but wiring the lights you will be fine with a regular automotive wire with fuses
Old Sep 16, 2008 | 12:14 PM
yeah i know i have wires that go from the power supply to the bulbs, and i know i can use regular wire and fuses on the pattern wires. i just need to know which kind i need for the power wire from the battery to the power supply itself
Old Sep 16, 2008 | 03:49 PM
DaBuzzard's Avatar
14 gauge will be lots, you could prolly get away with 16 if thats what you have on hand.
We installed a lot of these in the shop I used to work in (we were a Whelen dealer) and they do not draw a lot of power.
And if they are the strobe units, don't put fuses in the line between the power supply and light itself, these operate at about 600 volts, low current mind you. Just need to fuse between the battery and power supply.
Hope they aren't red and blue
Old Sep 17, 2008 | 07:15 PM
nope they are clear, because im alloud to use clear or blue lights for fire use only, and car shows. but i know not to fuse between the power supply and the lights.
Thanks, imma go pick up some wire and fuses one of these days and install them.
Coblt ss super
Nov 25, 2008 05:54 PM
GSoccer24
Aug 28, 2006 03:23 AM
hipfan39
Jul 11, 2006 12:04 PM
GSoccer24
May 24, 2006 01:43 PM
