Whoaa check this out
Old Oct 10, 2007 | 11:22 PM
Xavipheus's Avatar
Okay so ive had my projectors setup for awhile now, heres my situation:
With Automatic lights on durning the day just the Ambers are on, if i switch it up one notch all the leds and halos come on, one more up and bamm the headlights come on
So i decided to pull my Daytime Running Lamps fuse which has now made it so my ambers are always off except when i need my turn signal...SWEET
however i want my halos and leds to be on with my headlights are on at night, or at least always on, which wire should i tap for my LED/Halos for this?
Old Oct 10, 2007 | 11:26 PM
basketball0028's Avatar
can't you turn your ambers off durring the day by twisting it towards you? or go under your dic and turn off auto lights??
Old Oct 11, 2007 | 10:01 AM
CCBalla10's Avatar
i would agree to trying this first....might save you a bunch of work
Old Oct 11, 2007 | 10:40 AM
OrngBalt's Avatar
he already got the ambers off... I would think that you would have to tap the wire for the led's and halos into the DRL fuse so that they would come on always.
Old Oct 11, 2007 | 11:13 AM
PlaysWitCars's Avatar
Former Cobalt Owner
yeah i just turn my auto lights off during the day
Old Oct 11, 2007 | 09:39 PM
Xavipheus's Avatar
Yeah I do turn the ambers off durning the day but at night i want my headlights on as well as my LEDS- but still need functioning turn signals
UPDATE:
Pulling that fuse not only kills your DRL it also kills your interior lights such as your instrument cluster lighting, so that wasn't much of a solution ..........
Does anyone know which wire going to the turn signals is the constant power wire for the Daytime running lamps? I figure if I snip that wire it should cut the power for those and therefor leave me with working turn signals as i believe it receives power for that on a separate wire
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
