Whoaa check this out
Okay so ive had my projectors setup for awhile now, heres my situation:
With Automatic lights on durning the day just the Ambers are on, if i switch it up one notch all the leds and halos come on, one more up and bamm the headlights come on
So i decided to pull my Daytime Running Lamps fuse which has now made it so my ambers are always off except when i need my turn signal...SWEET
however i want my halos and leds to be on with my headlights are on at night, or at least always on, which wire should i tap for my LED/Halos for this?
Yeah I do turn the ambers off durning the day but at night i want my headlights on as well as my LEDS- but still need functioning turn signals
UPDATE:
Pulling that fuse not only kills your DRL it also kills your interior lights such as your instrument cluster lighting, so that wasn't much of a solution
Does anyone know which wire going to the turn signals is the constant power wire for the Daytime running lamps? I figure if I snip that wire it should cut the power for those and therefor leave me with working turn signals as i believe it receives power for that on a separate wire
UPDATE:
