RETROFIT Install questions and support!
Ok guys,
We still have some time before these are shipped, since the order was just placed this weekend.
I've noticed some discussion already about how people are going to wire them and people looking for a little assistance.
PLEASE use this thread to share your help and ideas. As a group I'm sure we can all make this very easy on each other, and it should keep Mike and my PM boxes from getting filled up too!
Thanks!
Thanks!
You can wire the halos directly to your headlights harness VIA sidemarker light. This means when you turn your fogs on, the halos will be on as well. But to run wires inside the cabin, behind the motor on the right side is a plug that comes out just behind the pedals inside.
Yea I would like to know the options for the halos as far as wiring them up. Can they be wired to the turn signals because they are always on. And does anyone know how to wire the fogs up so they come on automatically?
As for the foglights, we do sell a harness that wires them directly to your fusebox so no button is required. When the car turns on they turn on
tap them into your running lights. than they will stay on with low and hi beams. this is what i did my fogs are on all the time unless all my lights are off
Thanks for the reply!
Sub'd for the install!!
i bought new lights for these projectors, so when i get them i will get on the painting and when the projectors come in they can be installed immedietly
Sorry for any inconvenience! We promise the wait will be worth it. We're already thinking about our next GB.
As for a hair dryer, alot of people say they have used it and it worked for them. When I tried the silicone from where I first started would harden back up before I made it all the way around.
Other option is a heat gun.
