Manitoba SS 2013
Old Jun 9, 2013 | 12:38 AM
  #1351
Bluelightning's Avatar
Got Bewst?
So I got the car all back together and full of fluids. Go to turn it over to prime the oil pump, all I got was a loud click of a solenoid and my radio and headlights shut off. First thing I suspected was the battery. I pulled the battery out of my winter beater Cavi and same thing. So started checking for any bad or loose connections. None that I could see. Not like there's much for wiring that goes to the starter. I pulled the fuse box back out to see if there was a bad connection. Still no go. Bit of a head scratcher. I was getting frustrated so I left it for the night. Start back on it again tomorrow and see if I can figure out what the hell is going on.
I was so looking forward to hearing my car run tonight
Old Jun 9, 2013 | 09:23 AM
  #1352
slapbetcommissioner's Avatar
That's unfortunate to hear! Fresh perspective will help. You will get it figured out!
Old Jun 9, 2013 | 12:11 PM
  #1353
Got Bewst?
Ya after putting 5 hours into it yesterday my paitence was low at the end lol. It's gotta be a bad ground or a ground I forgot to hook up somehwere. I'm so damn close!
Old Jun 9, 2013 | 12:21 PM
  #1354
SylverSS/SC's Avatar
Sounds like a sensor is either unplugged or isn't fully connected. Could your crank position sensor be bad or not fully connected?
Old Jun 9, 2013 | 12:51 PM
  #1355
Got Bewst?
The motor should still spin over with a sensor disconnected
Old Jun 9, 2013 | 01:11 PM
  #1356
Gotta be a bad ground or something not hooked up quite right. Check the starter? Any chance it's not lined up properly or was broken during install. My 92 lumina did the same thing and the starter turned out to be sort of stuck and would just vibrate and tick. Replaced it and all was well. After that.
The car was sitting for quite a while maybe the starter got moisture in it or corroded.
Last edited by slapbetcommissioner; Jun 9, 2013 at 01:11 PM. Reason: Automerged Doublepost
Old Jun 9, 2013 | 03:04 PM
  #1357
Got Bewst?
But that still wouldn't explain why all my lights go out when the key is turned to the start position
Old Jun 10, 2013 | 01:07 PM
  #1358
Got Bewst?
The Balt runs! I'm having intermittent starter issues. Sometimes it works, sometimes it doesn't. And it didnt when I wanted to go for a test drive . So I gotta pull it out and see if it just needs some lube on the starter shaft or if I need a new one.
Old Jun 10, 2013 | 01:27 PM
  #1359
yellow dragon's Avatar
Old Jun 10, 2013 | 01:54 PM
  #1360
Garret's Avatar
vids or it didn't happen!
Old Jun 10, 2013 | 03:03 PM
  #1361
Got Bewst?
Ask and ye shall recieve
http://s441.photobucket.com/user/blu...tml?sort=3&o=1
Old Jun 10, 2013 | 03:07 PM
  #1362
Got Bewst?
I've got some reminisce of the blow up I gotta burn out of my exhaust though. Choooo Choooo lol
Old Jun 10, 2013 | 03:28 PM
  #1363
Cough cough! Did yu get the stuff for the catch can yet?
Old Jun 10, 2013 | 03:37 PM
  #1364
Got Bewst?
Sure did! It's all hooked up now.
Old Jun 10, 2013 | 03:42 PM
  #1365
Sweet.
Old Jun 10, 2013 | 03:57 PM
  #1366
Projekt's Avatar
Anyone want a 30 psi autometer cobalt boost gauge?
50 bucks .
Old Jun 10, 2013 | 04:00 PM
  #1367
Garret's Avatar
mmmmmmmm sexy
Old Jun 10, 2013 | 04:43 PM
  #1368
Got Bewst?
The neutral balance shafts definitely give the car some vibes at idle lol. I'm sure once I'm tuned they'll calm down a little.
Old Jun 10, 2013 | 11:32 PM
  #1369
Got Bewst?
So I got to drive my car! It idles like **** and wants to stall on deceleration coming to an idle. Gotta look if its the tune or a vaccum leak. And this thing is making way too much boost lol. I havent even wound it out and I'm seeing almost 30 psi on my gauge... I was seeing 27 at redline last year.
Old Jun 10, 2013 | 11:41 PM
  #1370
Projekt's Avatar
lugging it around again jeez
Old Jun 11, 2013 | 12:18 AM
  #1371
Got Bewst?
Can't teach an old dog new tricks
Old Jun 11, 2013 | 06:50 AM
  #1372
How high does the boost gauge go up to?
Old Jun 11, 2013 | 09:03 AM
  #1373
Got Bewst?
It's a 30psi gauge. And I don't like being able to bury it out lol.
Old Jun 11, 2013 | 10:02 AM
  #1374
It's ok Dustin, more bewzt is more powa, the obvious solution is to get a 40 psi gauge!
Old Jun 11, 2013 | 11:21 AM
  #1375
I say buy Jordans and wire them in sync then when you hit 30 psi the second activates and then your good to 60 psi..
