Manitoba SS's 2012 thread
NOOOO!!!!
I saw this earlier when checking in from my (old) iphone - and came back in hopes of seeing a dyno result... and just now saw that it was scheduled for next weekend.
That car moved like a banshee ~ I hope you find a replacement block, and get it back together without too much headache.
It would be a shame to lose the TVS.
Dustin, I like your car, I've made not qualms about this;
This does suck, but I for one, hope you stay supercharged...
There needs to be some LSJ lovin on this site ~ the kind which supports keeping it' supercharged.
A turbo isn't the end-all, cure-all ~ and IMHO, a clean build is best - so I'm of the mindset that an LSJ car should remain supercharged...
I hope you don't have too much problem finding a replacement block...
But when you do, I ZZP sells this nice piece;
ZZPerformance - ZZP Girdled Block #ZZ-GB-ECT
I would suspect that you might be able to buy the girdle (essentially an insert for the tops of the "floating" cylinder bores) separately...
The block is fine to put Dalton sleeves in. But Kevin has a spare. What's going back in it you may ask? Dalton sleeves, Diamond pistons, neutral balance shafts, 78lb valve springs and ARP head studs
. That block from ZZP is overkill for my hpLuckily my cousin just bought a house with a massive shop so that is where my car is going to be stored for the winter. Pull the motor out there, bring it to Kevin's and build the motor over the winter.
ah got it duh? Lol.
http://youtu.be/V84STSWVp3g
eh I'll probably put it away weekend 27th We can do it then. theres no heat, gravel floor. Great place to do work! lol
I can take mine off and deliver it to you if you want too
