Manitoba's SS's 2010
Old Nov 4, 2010 | 02:59 PM
  #551
yellow dragon's Avatar
Yep Winterpeg is colder.
Also with a block heater keeping the coolant warmer allows the engine to warm up faster therefore producing heat for the cabin faster, and also allowing you to not have to run the car longer then necessary hence saving fuel and emissions! A block heater sure helps when it is down near -40 before windchill.
Old Nov 4, 2010 | 03:37 PM
  #552
soundjunky's Avatar
Originally Posted by st3
2.) Average min. temperature in Winnipeg in January of 09: -25 degrees
Average min. temperature in Calgary January of 09: -12 degrees
Winnipeg winter's are wayyyy colder!
First off, last winter here was on average milder than normal - but averages don't tell it right;
When you average you takes highs/low and divide by days - I clearly said that we get temperature fluctuation, which you seemed to have missed.
Some peopel prefer your winters because the body adjusts to the cold, and it stays there;
around here we will never see the snow accumulation that you do, because we go through a cold-snow-warm-cold cycle which sees the snow regularly melt... which is also why we deal with more ice than you do.
I was born in Winnipeg, and have lived there at two separate points during my life;
Half of my extended family still lives there;
I am well aware of how cold it gets, and differences between here & there... like how we don't have any gun-slinging ninja bicycle riders around here
Wind chill only affects living beings - not cars.
I ever posted saying that block heaters ect were useless, but my recent post was merely trying to offer that you probably could get away w/o one...
I posted trying to help - I don't only lurk in the Winnipeg thread because the Calgary guys don't like me...
Old Nov 4, 2010 | 06:02 PM
  #553
Bluelightning's Avatar
Got Bewst?
Originally Posted by yellow dragon
So get this. At break when for a boot playing around with the interceptor and put it on the HP setting and punched it and i got a peak of 494 hp WTF! What a joke! Too Funny!
Wtf? Thats wierd lol. With this cold weather you must be makin lots of powa!
Old Nov 4, 2010 | 06:19 PM
  #554
Projekt's Avatar
sounds as accurate as walls dyno
Old Nov 4, 2010 | 10:14 PM
  #555
crazy-eh666's Avatar
Mike- glad to hear the guage works nice. Did you screw it in or 2 side tape it? It really is a nice pod and will set off the interior. And that 490 whp isn't a mistake, the interceptor has a built in hydrogen based flux capacitor that gives you all that power on demand. Teehee.
As for all this oil pan heater talk, is it really necessary to have one? My Balt seen one winter and i never plugged it in. Started every time no problem. She threw out heat quick too. It is synthetic oil after all... Just my 2 cents
Old Nov 4, 2010 | 10:43 PM
  #556
Got Bewst?
Lol well if that bastard would get back into town soon i could still redyno before the snow flies
Old Nov 4, 2010 | 10:54 PM
  #557
Projekt's Avatar
i blow my load on girls faces from 15 ft away more accurately then walls dyno
Old Nov 4, 2010 | 11:14 PM
  #558
Got Bewst?
Well apparently it's recalibrated. He did a before and after with a cobalt he borrowed from vickars and it was a 36whp difference. So he said he would give me a free dyno session. If it was that far out i think it's gonna be pretty close to motions now i think.
Old Nov 5, 2010 | 09:13 AM
  #559
Kennyspec's Avatar
two facts;
1) it's not the driving part that requires heating - it's the possibility of the coolant freezing/ and expanding, and the risk of cracking a block that requires the heating. So even if it wasn't winter driven, if it wasn't in a heated garage, it would have been subjected to the same freezing temperatures...
2) last time I checked, Winnipeg and Calgary have the same lows - but you guys have it stay in a deep freeze there for expended periods, whereas here it's a constant cycle of warming & cooling...
go take your oil and try and pour it at -40. it will be like pouring tar out of a bottle. now think how long it would take for this tar oil to flow through all the passages in the bolck and start lubricating your rotating assembly. I would be a lot more concerned about the viscosity of my oil at -40 than my coolant freezing.
They make coolant hydromoters to check and prevent your coolant from freeezing.
Old Nov 5, 2010 | 09:43 AM
  #560
st3's Avatar
st3
I can see why
I'm kidding, but all joking aside....all I want is a damn block heater or oil pan heater. There's no doubt in my mind it will start all winter, and if it doesn't - thats what GM Roadside is for!
Anybody have a remote start installed in theirs?
Old Nov 5, 2010 | 01:02 PM
  #561
slapbetcommissioner's Avatar
Most synthetic oils are rated to -35 and -58f before they get viscous
Old Nov 5, 2010 | 01:23 PM
  #562
Ya No **** eh? too funny. Tried it again last night and it hit 535 hp almost crashed from laughing so hard.
Old Nov 5, 2010 | 01:25 PM
  #563
soundjunky's Avatar
I can see why
This one I know because of having been in the industry years ago;
most auto starters are not setup to work with m/t cars becasue there's no way of verifying that it's not in a drive gear - but I've understood that you can have an autostarter installed in a MT car...
to have one installed in your car, you're either going to give up your spare key, or have a spare made, which will be "sacrificed" for the auto starter to work - but doing so effectievely disables your anti theft;
the reason why I say this is that either the whole key, or the part of the key with the chip in it needs to be mounted as close as possible to the actual ignition lock cylinder to "fool" the anti-theft into thinking that it's ok to start.
I don't know if GM offers any kind of remote start that doesn't require a key be sacrificed, or if the aftermarket has gotten to the point where sacrificing a key is no longer needed... but there would have to be some kind of "fix".
I hope this helps you some.
Please post up on if you do install either a coolant or oil heater - and which brand/where you bought it from - as I for one am interested.
Old Nov 6, 2010 | 08:54 PM
  #564
Kennyspec's Avatar
there is a vehicle weight calibration. enter your correct weight.
Old Nov 7, 2010 | 05:21 PM
  #565
the weight must be calibrated at 7400lbs lol.
Old Nov 8, 2010 | 12:10 PM
  #566
st3's Avatar
st3
These are cheap:
cobalt ss winter tires and rims - Winnipeg Tires, Rims For Sale - Kijiji Winnipeg Canada.
Old Nov 8, 2010 | 12:14 PM
  #567
soundjunky's Avatar
those are the G6 steel rally wheels.
I have seen them on several non-LNF cobalts - but they will not fit LNF cobalts without a brake swap.
Old Nov 8, 2010 | 01:10 PM
  #568
cool thanks gonna give em a call
Old Nov 9, 2010 | 08:40 AM
  #569
Got them for 160
Old Nov 9, 2010 | 03:02 PM
  #570
Got Bewst?
Got them for 160
Now you need 2 summer tires lol
Old Nov 9, 2010 | 03:24 PM
  #571
st3's Avatar
st3
Got them for 160
Smokin deal!
Old Nov 9, 2010 | 06:21 PM
  #572
Projekt's Avatar
st3 i saw you driving down keewaitin today
Old Nov 9, 2010 | 06:36 PM
  #573
wow creep much?
Old Nov 9, 2010 | 06:50 PM
  #574
Projekt's Avatar
i was heading the other way to work.
Old Nov 9, 2010 | 08:59 PM
  #575
So are most of you guys gonna drive your cobalts this winter?
