Manitoba's SS's 2010
Give it up for Tandy yo! Gonna play some Neo Geo, play B-ball in my pump hightops, pick up some acid wash, then I'm going to the theatre to watch The Wizard, and buy a Power Glove.
ah..... good times.
ah..... good times.
lmao good times indeed. and dont forget to blow into that nes cartrage for 5 minutes before putting it in. lol Sit there playing mario 1 sporting some neon slush pants. wooooo. them were the days
"I love the power glove because it's so bad".
**** man. Power Blove, Virtua Boy, Super Scope. Life used to be full of amazing ****. Max Headroom. Haha.
Hey Ryan, if the Mackers and I drive up at Easter, would you be able to hang? Or are you busy with the fam?
Finally got my collector jig together and tried it out tonight. First collector is on a 15* angle, looks not too bad, I may 10* next. The cutoff distances arent perfect but its a **** of a lot better than by hand. car should be turboed in a month....for the third time
First cut
Second cut
Then i end up with 4 of these
Tacked together
Doesnt fit perfectly in the center but a little massaging with a hammer will fix it.
First cut
Second cut
Tacked together
dunno what numbers it will put down, prob up around 420whp ish area lol.
Got finished the part that i was fearing the most, making the header. Its didnt end up being equal length but im fairly happy with how it turned out. Took me about 6 or 7 hrs, all freehand cuts with a angle grinder. And teh best part is I only had to take off the axel shaft running from the trans to the pass side to get the header up there. For a while it looked like the subframe had to be dropped it fit it in there
just tacked together, i need to go buy some fittings to make a backpurge setup on my tig before i weld it.
I work for a Geotecnical Engineering company in wpg. I just do this car **** as a hobby
first i bought a flow valve for backpurging
first pipe on
number2
number 3! started to get tricky to weld.
plugged up for back purging
and finally its done. just need to weld it to the head flange
first pipe on
number2
